Extended lugnuts
Old Jan 30, 2009 | 11:03 AM
averageG05's Avatar
Extended lugnuts
I just bought a pair of the 30 mm wheels spacers and I was wondering if I will have to buy extended lugnuts as well
Old Jan 30, 2009 | 11:40 AM
G35Papa's Avatar
No
You probably got the spacers with built in studs right? Basically the spacers will go over your existing studs and the studs on the spacers will be about the same length as the OEM ones.
Old Jan 30, 2009 | 12:05 PM
INF G'd Up's Avatar
ya when you put the wheel spacers on the studs will not stick out further than oem , so wont have to buy extended lugs
Old Feb 2, 2009 | 12:06 PM
waijai's Avatar
i.love.gold
I just bought open ended lugnuts to use...my studs are way longer than stock.
Old Feb 2, 2009 | 02:40 PM
averageG05's Avatar
and you have wheel spacers with the built in studs
Old Feb 4, 2009 | 11:50 AM
waijai's Avatar
i.love.gold
No, I used to have H&R wheel spacers which had separate spacer and studs. They were used with my old wheels after I installed front and rear BBK. Now that I have new wheels, the spacers weren't needed, but I kept the studs in there and just bought open ended lugs.
Old Feb 4, 2009 | 12:03 PM
redlude97's Avatar
I'm not following how that is pertinent to this thread....
Old Feb 4, 2009 | 12:42 PM
INF G'd Up's Avatar
True , but it looks like average asked what type of spacers waijai had, I wonder if average pulled the trigger and bought some extended lug nuts
Old Feb 4, 2009 | 12:45 PM
averageG05's Avatar
Thanks everyone for helping with my question, I did get a set of muteki ce lugnuts and they worked good , i didn't need need extended lugnuts
Old Feb 4, 2009 | 12:47 PM
INF G'd Up's Avatar
Good to hear, what color lug nuts you end up getting
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
the93owner
Oct 4, 2015 09:40 AM
