TPMS nut coming loose on aftermarket 1-piece wheels
Old Jan 30, 2009 | 12:40 PM
heyitzalex's Avatar
Any of you guys have this issue? I torqued the nut down to the spec listed in the manual (60-72 in-lb, I just did 72), but it seems like after highway driving the nut comes loose. I actually had a couple flats because the nuts were loose. Will a TPMS rebuild kit (rubber seal and nut) help? Either that or i'll go back to the trusty rubber valve stems
Old Jan 30, 2009 | 12:49 PM
redlude97's Avatar
Most likely the holes on the aftermarket wheels are larger than the OEM holes, which doesn't allow for proper sealing. Band the TPMS sensors and use traditional valve stems
Old Feb 1, 2009 | 10:41 PM
heyitzalex's Avatar
the previous owner of these wheels used lexus tpms just fine. either my tpms needs to rubber seals (but i still don't see how that would cause the nut to come loose) or my infiniti sensors doesn't have enough threads to lock securely. i might try the tpmssolution valve stems.
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
atk08
Jul 30, 2015 03:12 PM
rping
Jul 26, 2015 09:53 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
si_driver
Jul 14, 2015 12:29 PM
