Yet Another Spacer Question
Old Feb 7, 2009 | 05:47 PM
jhu1011's Avatar
Hey Guys,
Just got some 20" Axis Penta's for my G and I'm thinking about getting some spacers to push the wheels out some more. However, I don't know what type of spacers and what size to get. I am dropped on Tein S-Tech springs for the G coupe. I also did the Rear Spring Mount Mod and cut about 1/2" off so I should be dropped about 1.4" in the back.
I was wondering what size spacers I should get and whether I need to roll my rear fenders or not. Any input would be appreciated!
-Jeff
Old Feb 8, 2009 | 10:30 AM
INF G'd Up's Avatar
whats the offset on your wheels
Old Feb 9, 2009 | 12:24 AM
jhu1011's Avatar
oh sorry my offsets are +25 for both front and rear. 20x9 up front....20x10 in rear.
Also, i dont know whether to go with Project Kics, H&R, or Ichiba V2 spacers.
Old Feb 9, 2009 | 12:25 AM
jhu1011's Avatar
Tire sizes are 245/35/20 up front and 275/30/20 in the rear.
Old Feb 9, 2009 | 12:27 AM
jhu1011's Avatar
I just want my front wheels to be flush with the fender and my rear wheels to poke out just a little bit.
Old Feb 9, 2009 | 12:32 AM
bigc's Avatar
Wings Nation
you can easily fit 10-15mm spacers if you roll your fenders. 10mm spacers will require you to install longer studs (unless you go with the non-hubcentric project kics ones) while you can get bolt-on type 15mm spacers from most of the big manufacturers (eibach, ichiba, project kics, h&r)
INF G'd Up's Avatar
you can do 20mm in front, 25mm in back
Old Feb 9, 2009 | 12:34 AM
bigc's Avatar
Wings Nation
^ that's really aggressive. its been done and looks pretty sick, but you'll have run mad camber and will probably rub your fenders.
Old Feb 9, 2009 | 12:35 AM
INF G'd Up's Avatar
I have used ichiba ver 2 wheels spacers built in studs with hubcentric for the g35 and worked really good
jsimonk
Dec 22, 2023 03:49 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
