Yokohama Avid W4S
Old Feb 8, 2009 | 06:45 PM
jimmykce1's Avatar
Yokohama Avid W4S
I installed a set of of 4 tires on my 06 sedan. I put about 2500 miles on them and the rears are bolder line passing state inspection. I taught these tires were supposed to last 30k. I guess these tires are very soft compound. My front tires are good. Looking at getting Michelin Pilot Sport plus which come with a 45k tread life.
Attached Thumbnails Yokohama Avid W4S-closeup-front-driver-side-tire.jpg   Yokohama Avid W4S-closeup-rear-driver-side-tire.jpg   Yokohama Avid W4S-rear-passenger-side-tire.jpg
Old Feb 8, 2009 | 07:42 PM
Mustang5L5's Avatar
I had those tires on my Mustang GT. I put 10K miles on them before trading the car in for my G35. They were nowhere near as worn as that. I could easily have gotten 25-30K out of them by the looks of the wear at 10K miles. They are actually a pretty hard compound and have a 400 wear rating.
WHen was the last time you got an alignment? You should not have that type of wear at 2500 miles unless something is seriously out of whack in your suspension or you were doing a lot of burnouts or something
Old Feb 8, 2009 | 08:37 PM
AARONHL's Avatar
Clearly, the rear is out of alignment.
Old Feb 8, 2009 | 09:01 PM
5150DS's Avatar
I have had those exact tires on my G for 15k and they should be good for another 15k. As said above, did you get an alignment when you got new tires. They are a hard compound tire (400 tread wear rating) so they are designed to last.
Old Feb 8, 2009 | 09:24 PM
Braintree's Avatar
Photos indicate you may have a serious toe-in problem (front of the wheel pointing in towards the center-line of the car) since the tire has been shaved on the outer edge. An alignment, as others have suggested, should do it. Even the most expensive and highly rated tire will show this kind of wear if the alignment is off. Good Luck!
Old Feb 9, 2009 | 03:23 AM
Spec R's Avatar
yep dont blame the tires, blame the alignment
Old Feb 9, 2009 | 07:35 AM
Mustang5L5's Avatar
You can see in the 3rd pic that the wear is abnormal due to the rubber "tearing" to the side and the rubber having a lip on the blocks.
Get an alignment before getting new tires.
Old Feb 9, 2009 | 01:35 PM
jimmykce1's Avatar
I am having the alignment checked. I had the aligned mid last year so it should of been okay. I guess TireRack probably will not find the tire defective according to the comments here. So I guess I will have to get new tires..sucks.
PS: I do drive a little aggressive but not what my tire is looking like now.
Old Feb 9, 2009 | 02:35 PM
Tollboothwilley's Avatar
Sounds like your rear camber is out. That will tear up the tires VERY fast.
I've had these on my stock 17's for almost 2 years, get about 40-45K miles on them.
I had a camber issue for 50 miles and burned up almost 15K miles of tread in that time.
I upgraded rims, so now I have 2 225/55/17's left over...which are basically brand new.
Old Feb 9, 2009 | 05:09 PM
MAXSE2KMT's Avatar
not to be redundant, but i would have to agree with what has been said here. i have these tires on my car for 10k and they look almost new. camber wear seems apparent in the pics
Old Feb 9, 2009 | 05:15 PM
Jeff92se's Avatar
Red Card Crew
Toe can really screw up tire wear (as noted). If you have your specs, list them up. Someone might be able to see where the problem is.
Old Feb 9, 2009 | 05:31 PM
snavematt's Avatar
just a sedan
toe is def off, mine looked worse than that at 2500 miles,
Old Feb 9, 2009 | 06:52 PM
jimmykce1's Avatar
I had my car aligned at 17,955 miles new tires went on at 18,800miles. The rear toe was set at -0.12 left rear and -0.13 right reear, I believe.
Old Feb 9, 2009 | 07:01 PM
snavematt's Avatar
just a sedan
get it rechecked, mine was "inspec" but went somehwere else and it was totally off, they fixed it, and no problems since
Old Feb 10, 2009 | 07:51 AM
jimmykce1's Avatar
Having the wife take it up to get checked out this morning.
