19x9 +35 on sedan
Old Feb 28, 2009 | 09:59 AM
Texasscout's Avatar
I'm running 19" by 8" 30 offset with 245 40 19. One inch drop with 350Z springs.
If I go any lower, the roads around here would eat me alive.
Old Feb 28, 2009 | 12:27 PM
Gsedan35's Avatar
Originally Posted by Gdup35sedan
they'll fit fine front and rear. The front you'd need a 245/35/19, the rear you could run a 255/35 or 275/35 if you want to go really wide.
Or you could opt for 255/35 all around and keep the option of rotating.
-GP-
The 255/35-19 fitment in the front will NOT work if you exercise any kind of camber correction. You have to be willing to run higher negitive camber levels to make it work. I know I had the same type of setup and as soon as I dialed out a bit of camber, game over with a unliveable amout of rubbing. Thankfully for me it was a simple as pulling out the 10mm spacers I was running bringing me back to a 45mm effective offset. Just to say it the tire that didn't clear had a sectional width of 9.8" and a tread width of 9.1", a 255/35-19 RE50A has a sectional width of 10" and a tread width of 9.3", so on that tire, clearanes would be worse.
You cannot do the 275/35-19 on the rear with that high of a offset without rolling the rear fenders.
I have done clearance test's where I removed the springs out of one side, put the tires and wheels back on and checked clearance from full extension to the bumpstops.
Jusseth
Sep 13, 2020 12:25 PM
TheKnite
Aug 14, 2015 07:59 PM
chinee
Aug 8, 2015 10:11 AM
BlackGee35
Jul 31, 2015 11:04 AM
teamghost
Jul 28, 2015 04:52 PM
