20" rim question
Old Feb 20, 2009 | 03:38 PM
SD_GCoupe's Avatar
20" rim question
So I'm considering getting some 20" Axis Penta rims for my G. I'll prob do 20x9 in the front and 20x10 in the rear. I have the Brembos so I'm just wondering what else is needed. Do I need a camber kit, spacers (what size?), springs, roll the fenders? I hear all this talk and just not really sure what I'd need. If anyone who has done this could give me a cost break down for all the parts and labor they needed it would help a ton! Thanks guys!
Old Apr 27, 2009 | 04:50 AM
sinasajadi's Avatar
yea I need help in the same exact area. please someone chime in... thanks
Old Apr 27, 2009 | 12:37 PM
mchamps's Avatar
I am sure that Pentas clear Brembos. 20"s on stock suspension looks like a 4x4, you will not like the stance. You will need springs, and a rear camber kit, then top that off with an alignment after a couple of weeks.
Dependent on the rear tire width, you will need to roll the rear fenders as well.
Old Apr 27, 2009 | 02:31 PM
sinasajadi's Avatar
camber kit
Im getting the pentas today, and I will lower my car soon. I was only going to do a slight h tech for g35 drop. I know it is a very subtle drop, but my question is"
with 20'' axis pentas and a h tech for g35 drop, will I need to get a camber kit and/or roll my fender if I get 275/30/20 tires ?
someone please help me??????? thanks
Old Apr 27, 2009 | 02:46 PM
LaConic2's Avatar
one way to find out. SLAP it all on...then process of elimination:
-u can play it safe and get a camber kit, or if the shop can align with minimal wear try that (kits run 150-200+) for the rears
-fender rolling 75-100+ per side..
-i would wait till you get the springs to put ur rims on, so u can get them aligned at teh same time...so ur not wasting money on alignments..
i think u'll be fine, without the roll. htech dont drop at much. leaves a gap in the rear.
unless ur hauling fat chicks all the time..JK man
Old Apr 27, 2009 | 03:16 PM
sinasajadi's Avatar
the gap in the rear is fine its just the huge gap in the front im worried bout. how much to get a camber kit installed? also do you think i should go 285/30/20 or 275/30/20 in the rear, wouldnt getting the 275's better my chances of rubbing?
also what are peoples opinion on yokahama avs es100 275/30/20 tires. They are going for $121 each thats a good deal on tires no?
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
Kng0fHrts
Sep 15, 2015 05:40 PM
hurleyguys
18 Inch
Sep 9, 2015 12:24 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
EasySausage
Jul 14, 2015 11:17 PM
