tire pressure need help
Old Jun 24, 2004 | 02:46 PM
TimSuper's Avatar
hey guys, i am a little confused about how much pressure i should have in my g35 auto.
on the door it says 30 psi front and back, but when i checked my tires using a digital gauge for the first time today i found one of them having 42 the other 3 around 39, so i let some air out so they are now all around 30, but i am a little worried maybe i let too much out.
Is it correct that i should have 30 in my tires?
G35-Forum.com
Old Jun 24, 2004 | 04:25 PM
KingoftheRoad1's Avatar
Re: tire pressure need help
Generally a good rule of thumb is to keep the pressure about 10% higher than the recommended one. Reasons are: one, losing pressure is directly related to time, speed, temperature,etc. Therefore, at 30lb, your tires are running underinflated quickly.Two, it is always better to run at slightly overinflated than under. I have been doing it for a long, long time. In conjunction of periodic alignment, my tires last for a long time. I fill mine at 33. Hope this helps.
2004 G35X
Old Jun 25, 2004 | 10:24 PM
ryoken's Avatar
32-35 is good for driving around town. 38-42 is autocross/track day pressure. It rides way too rough for regular street use.
jsimonk
Dec 22, 2023 03:49 PM
Danielek
Sep 20, 2015 12:08 PM
JoeMac
Aug 20, 2015 10:17 AM
