Why am I cambering??
Old Mar 31, 2009 | 01:13 PM
lfaboulos34's Avatar
Im on stock springs w/20mm ichiba's on the back. Why am I cambering??
Old Mar 31, 2009 | 05:31 PM
STCLAIRWEST's Avatar
I think these cars come a little cambered out of the factory.
Old Mar 31, 2009 | 06:19 PM
eurodre's Avatar
camber is not that bad, chill out, as long as ur toe is in spec
Old Mar 31, 2009 | 07:25 PM
poonATTACK's Avatar
Hey could you post some pics? I was thinkin about spacing my rears but wasn't sure how it would look on stock springs..
Old Mar 31, 2009 | 07:29 PM
Im trying to drop it on s-techs so i will need a camber kit ontop of that. it doesnt camber bad at all with the spacers, i can just tell its slightly cambered when i look at the car from the side and my friends when they drive behind me say it cambers.
Old Mar 31, 2009 | 07:33 PM
eurodre's Avatar
like i said guys chill out on the camber what is the toe you guys r getting?
Old Mar 31, 2009 | 07:39 PM
Blackmouf's Avatar
Don't worry about it. I can't answer your question but make sure you buy the full kit when you lower on S Techs. Best of luck
what do you mean?
Old Mar 31, 2009 | 07:42 PM
camber and toes? what do you suggest.i was just thinking of getting the camber kit for the back for now, moneys tight
Old Mar 31, 2009 | 07:52 PM
eurodre's Avatar
Originally Posted by lfaboulos34
what do you mean?
im saying what was your toe when you got an alignment? camber wont affect tire wear as much as toe will
Old Mar 31, 2009 | 08:05 PM
never got an alignment yet but will when i drop it on the s-techs
Old Mar 31, 2009 | 08:29 PM
eurodre's Avatar
^^koo good stuff
Old Apr 1, 2009 | 02:16 AM
Blackmouf's Avatar
I recommended the full front and rear kit in my previous post. If your just looking to get the rear kit, make sure you get the toe bolts with them. The toe bolts are a fairly inexpensive add on to the SPC rear camber arms but it's what really makes the difference. Like everyone has said, it's better to have the toe in spec and then the camber.
You should be able to find a used rear camber kit with toe bolts for $150 shipped or less. Check the marketplace both here and my350z.com
Old Apr 1, 2009 | 10:32 AM
eurodre's Avatar
also with the toe bolts.. be aware that you MIGHT run into the same problem i did.. they were too short so i called up spc and they told me that maybe my car is a late model 06 and they sent me an 07 toe bolt.. so be aware of that as well
Old Apr 15, 2009 | 06:11 PM
will i be able to get back in spec on the rear with the stock toe and camber when i get an alignment after i drop it on s techs?
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
Rose M
Oct 12, 2015 10:00 AM
