Change tire size
Change tire size
Hey 1st gen Sedan guys:
Right now I'm running 245/45-18 tires on 18x8.5 45mm offset wheels all around. My car is an 03.5 2WD 6MT with a 1" drop using a revised 350z suspension. I currently have no rubbing issues, and the tires look almost flush with the body sides. I want to go with 265/40-18 to get the right diameter so my speedo will be correct. Will I have rubbing issues?
Thanks.
Thanks.
