19X9.5(+22)F & 19X10.5(+22)R fender roll?
Old Apr 9, 2009 | 06:02 PM
jonnylaw's Avatar
Looking at a set of CE28n in 19X9.5(+22)F & 19X10.5(+22)R. I have mild drop (~1.3 in) with nismo cpv35 suspension.
Is there a certain tire size that is ideal for this size and offset? And would they rub the fender without rolling?
I have read some Z posts saying this setup rubs the rear fender when going over dips, while others do not report any fender rubbing.
Also, would it be a good idea to get a camber kit, or is that unnecessary?
thx in advance.
Old Apr 9, 2009 | 06:08 PM
intense660's Avatar
more than enough room, no roll required.
im running TE 37's same size and offsets
Old Apr 9, 2009 | 06:18 PM
redlude97's Avatar
what size tires?
Old Apr 9, 2009 | 07:55 PM
Triple8Sol's Avatar
If you go 245/35/19 & 275/35/19 you won't rub. Wider and you prob will. Seriously though, get your fenders rolled so you can run wider tires or spacers to make them flush
Old Apr 9, 2009 | 09:09 PM
GReddySetGO's Avatar
+1 with all the above comments.
I am running LE27s, in those exact sizes/offsets. I do not rub with 245/275, but I do rub with 255/285. Rolled the fenders, problem solved.
Old Apr 9, 2009 | 09:29 PM
pedrodjss's Avatar
i am having the same issues with a sedan. my plan is to put Two 19x8" (20mm offset) and Two 19x9.5" (20mm offset) or Two: 19x8" (40mm offset) and Two: 19x9.5" (35mm offset). fenders are rolled and has lowered suspension. not sure if they will rub.
Old Apr 9, 2009 | 10:54 PM
g35koupe's Avatar
I'm running 255/35 on the front with the same offset, no fender roll and no rubbing. I've got about a 1.5" drop. 275/35 on the back, same deal.
Old Apr 10, 2009 | 01:04 AM
Same here, 255/35 up front, no rubbing. However I have 285/35 in the rear and that rubs w/o rolling
Old Apr 10, 2009 | 09:34 PM
jonnylaw's Avatar
Thx for the all the help guys. Looks like I'll be going with 255/35/19 upfront and 275/35/19 in rear. Now time to research tire brands . Any suggestions on tire brands/models are appreciated--looking for sticky street tire that can still handle ok in the rain.
Old Apr 10, 2009 | 10:51 PM
GreenGoblin's Avatar
The goblin resurrection
I would suggest the Nitto line up
Old Apr 10, 2009 | 11:35 PM
jonnylaw's Avatar
Thx for the reply. Do you have any experience with Nitto NT05 or INVO?
Old Apr 11, 2009 | 12:05 PM
When it comes to tire selection, it really depends on what you want. There is a lot of compromise/sacrifice to be made.
Real sticky tires are often not so good in the rain, cost a lot, and wear out fast.
Personally, I don't wish to spend $1200 on tires, to only have them last me 6mo. Rather I just use decent, affordable street tires. Then have a dedicated track setup for the fun stuff.
There are a lot more affordable street tires you can get now that will perform OK, but be able to do well in rain as well, not break your wallet, and last. For tires in this category, I would suggest Yokohama S-Drive, Falken FK-452, or even Kumho Ecsta SPT. You should be able to get a set of either of those for $6-800, and they should last you well over a year or much more, depending on your driving style and how many miles you drive in a year.
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
DRG35R
Jan 31, 2016 07:14 AM
dcsbh1
Oct 1, 2015 03:15 PM
NyCrAzY
Oct 1, 2015 09:19 AM
