I hope this isn't a stupid question about the OEM wheels!
Old Apr 24, 2009 | 10:47 PM
islandgrown83's Avatar
I can't find any solid answers on a few things about the OEM wheels on the 2004 g35 coupe 6mt. First, are the RIMS staggered? 18x8 all the way around or are the rear's wider? And can I fit a 255/40/18 on the rears of the OEM rims?
Old Apr 24, 2009 | 10:53 PM
eurodre's Avatar
i believe its 18x8 +30 all around
what do you mean CAN you fit? do you mean WITHOUT rubbing? if so, yes most likely you can
Old Apr 24, 2009 | 11:00 PM
Yea, what can fit without rubbing. Basically, would a 255/40/18 be to big of a tire for the OEM wheen of the 04 G.
Old Apr 24, 2009 | 11:05 PM
gomd3's Avatar
yeah coupes are staggered, Im running 255/40/18 in the back no prob. Front are 8 rears are 8.5 so you're good to go.
Old Apr 24, 2009 | 11:07 PM
eurodre's Avatar
oh even the 18s are staggered? thats cool well there u go OP
Old Apr 25, 2009 | 01:03 PM
idrive_MD's Avatar
NO NO NO, the OEM 18" WHEELS ARE NOT STAGGERED!!! From the factory, the tires ARE staggered, but never the wheels, not until the 05 Sport Wheels came out in the 19x8 and 19x8.5 size.
Factory spec of the 18" coupe wheels is 18x8+30 offset front and rear with a 225/45/18 front tire and a 245/45/18 rear tire.
You can put a 255/40/18 on all four wheels and not have to worry about rubbing. I use 235/40 on all four of my wheels with an M+S rated all season and that is a very minimal stretch (I know its a stretch because when I lay the wheels down, the wheel touches the ground and not the tire's sidewall).
There is nothing wrong with putting a non-staggered tire setup on the OEM 18's, but at the same time there is nothing wrong with going with a wider setup front and rear. I know some people have fitted 245/40/18 front and 275/40/18 rear (but the 275 does bulge).
Old Apr 26, 2009 | 05:31 PM
Thanks
Thanks for all of your responses.
Old Apr 27, 2009 | 12:03 PM
bocatrip's Avatar
The 18" rims are not staggered. They are 8" width all around. The tires are staggered. It's only the 17" rims that are staggered, 7.5" and 8".
Old Sep 27, 2009 | 03:27 PM
rynoinaz's Avatar
wheel sizes on 6mt coupe with brembos
the wheels on my 2003 g35 6mt are all stamped 18x8JJ and 30 (offset). however the front ones are stamped FRONT, W238 and the rear ones are stamped REAR, W239.
ARE THE FRONT AND REAR WHEELS IDENTICAL OR NOT??? if they are the same, why would Nisan stamp them FRONT/W238 and REAR/W239?
any help is greatly appreciated!
thanks!
Old Sep 27, 2009 | 03:38 PM
Texasscout's Avatar
thanks!
That's because of the "index pin" on the back wheels. You can't rotate tires.
Blakearold
Aug 27, 2015 12:37 PM
Detailed Image
Jul 24, 2015 12:31 PM
EasySausage
Jul 14, 2015 11:17 PM
