uneven drop with tein s.techs, is this normal?
Old Jul 9, 2004 | 12:08 AM
Eurog35's Avatar
i notice that my car with stock 18's and michelin pilots, when i first got my car done, it was even, about a 1 1/2 finger gap for the rear and front, but after a few days, my back is now lower than the front? is this normal? my back is 1 finger gap now, and the front is 1 1/2 finger gap... sigh the rear is lower than the front, what gives? is it because my rear settled 1st? if so, should i give the front some time to settle a lil and hopefully it'll even out? I know its hardly noticeable, but im picky when it comes to my car... anyone experience the same when installing their s.techs? does driving fast and cornering fast have anything to do with this when i 1st got my car? am i suppose to drive normal to break it in or anything?
Old Jul 9, 2004 | 12:23 AM
Gsedan35's Avatar
Re: uneven drop with tein s.techs, is this normal?
It's normal for these cars, no matter the spring, so be off as much as a 1/4" from corner to corner. My car is, the left rear is 1/4" lower. And other's have reported simular variences as well.
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
Old Jul 9, 2004 | 09:29 AM
SilverG35C's Avatar
To be honest if you are that picky you should look towards coilovers as an alternative setup. Most any spring setup you get will not drop consistently on all four ends when settled.
Jason Siu
G35STUFF!
Got a Coupe?
jasonsiu.net
Old Jul 9, 2004 | 11:31 AM
GG35's Avatar
maybe because the back has less gap than the front stock....
Old Jul 12, 2004 | 01:31 PM
coreyen's Avatar
i've had this experience in the past with my hondas. make sure when you install the springs you put the springs that are slighly taller (due to mfr. variances) on the driver side when you install them as usually those will get the most weight. but I agree adjustable coilovers are probably a better way to go if you want to get that "perfect" look.
G35C 6MT DG Prem.
Old Jul 13, 2004 | 06:40 PM
Eurog35's Avatar
no, the left and right side of the car is even. I'm talking about the front is higher than the back... i think it's because i didn't cut 1 inch off my bumpstops like it said in the tein installation manual... hrmm, but will i be ok w/o cutting the bumpstops, or should i cut them? please help...
if i do happen to cut em, and later on decide to sell my car, where can i purchase the factory bumpstops and how much would it cost around? Thanks.
nissandrifter32
Dec 22, 2015 04:28 PM
G35xdriver04
Nov 7, 2015 08:31 PM
wuzz-upp
Oct 3, 2015 04:21 PM
bigmike
Sep 17, 2015 01:58 PM
NJ6MT
Sep 10, 2015 08:40 AM
