treadwear on tires?!
Old Jul 9, 2004 | 01:53 PM
Raznips's Avatar
What is the treadwear on a set of pilot sports? the tires that im getting when i get my volks in a couple of weeks are 280 (t1's) and iw as just wondering how many miles should they last me with me driving moderately hard
2004 Black on Black g coupe 6spd.... aluminum pedals, clear corners, z tube, and pop charger. soon to have 19" volk gt-c's and PIAA xtreme whites in the clearance and corners
Houston Texas
Old Jul 13, 2004 | 10:53 AM
Raznips's Avatar
Re: treadwear on tires?!
hulllo out there!
Houston Texas
Old Jul 13, 2004 | 11:01 AM
al503's Avatar
the pilot sports are 220. However, the treadwear ratings should be taken with a grain of salt especially between different manufacturers.
Old Jul 13, 2004 | 11:39 AM
Q45tech's Avatar
Treadwear is a function of load and load index also. If you want longer life in the same tire just changes sizes to get a higher load index. Roughly the gain [%] in load index is reflected in the same or greater {%} of life extension, some times adding 6% [increased load safety margin] can get you 10-12% even 20% increase in tire life due to lower peak internal [where tread block attaches to tread carcass] temperatures.
Lots depends on how /what wears them......spinning burn outs or road roughness slewing..........modern roads surfaces[ rough ashpalt] are designed [byproduct of it] to wear tires fast to improve wet grip!
Kind of counter to improving automobile mileage increased road friction.......but wet kills on a smooth low friction roadway.
Old Jul 13, 2004 | 01:09 PM
Raznips's Avatar
well i dotn really launch my car. I chirp the occasional gear and get sideways occasionally (mostly when its wet out), but i realize that that changes the life of my tires. I just didnt want to get tires that i would be replacing in 8k miles or somehting
Houston Texas
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
philthethrilloh
Sep 9, 2015 01:25 AM
socaldavid
Sep 5, 2015 04:35 AM
