Brembo rotor problem
Old Jul 10, 2004 | 11:21 PM
laklein's Avatar
I was checking out a brake squeal, and on the inside front rotor was a quite large groove. It measured approx 1/8 inch in width and very palpable.Would anyone know if there is a risk driving and if it is covered for repair? I have the Brembo's.
Thanks. Laklein
2004 6mt Ivory/willow prem aero
Old Jul 11, 2004 | 01:31 AM
cke73's Avatar
Re: Brembo rotor problem
There is a TSB for the front brake squeal during breaking when doing reverse. Not sure if yours is like that. But if it is, you might want to try searching for it here: http://www-odi.nhtsa.dot.gov/cars/problems/tsb/
Old Jul 11, 2004 | 06:29 AM
Q45tech's Avatar
Is this groove under the pad area or are you speaking of the heat isolation slots near the rotor hub.
Old Jul 11, 2004 | 03:08 PM
cke73's Avatar
There is the TSB for replacing front brake shim. See the TSB link here: http://www.infinitihelp.com/Ownershi.../ITB03-069.htm
Old Jul 11, 2004 | 10:19 PM
laklein's Avatar
Thanks for the TSB link. I'll research it. And as to the position of the groove, It's mid-line pad and rotor.I appreciate the help.
Laklein
2004 6mt ivory/willow/prem/aero
Jiggerjuice
Oct 5, 2015 02:33 PM
Jiggerjuice
Aug 26, 2015 09:00 AM
miata007
Aug 17, 2015 04:36 PM
Terry_G35
Aug 4, 2015 02:38 PM
RedBaronK
Jul 27, 2015 03:19 PM
