Fat rear tires
Old May 12, 2009 | 06:59 PM
Blair15951's Avatar
ok but lets pretend
Old May 12, 2009 | 07:01 PM
Blair15951's Avatar
ok but lets pretend for a moment
that we have a perfectly flat surface.. made of uniform material
the tires are all exactly the same: same material, same tread, no distortion
the car is exactly the same
why is a wide tire better than a narrow tire
Old May 12, 2009 | 07:12 PM
redlude97's Avatar
If in your imaginary situation where tires do not flex and tires do not wear or slip and you are dealing strictly with static coefficient of friction, there is no difference. This is so far from a real world situation it is pointless to make any type of correlation.
Old May 12, 2009 | 08:50 PM
Blair15951's Avatar
ah but see you are wrong
im done arguing this
its not going anywhere
Old May 13, 2009 | 08:40 AM
idrive_MD's Avatar
the answer is simple...it looks awesome!!!!
seriously though, you're arguing over ideal situations vs real world applications. Like others have said and you have clearly agreed upon, in the real world where surfaces vary, tire pressures and compositions vary, the wider bigger tires assist in grip.
In ideal vacuum type situations, your thoughts are correct as well, a wider tire in an unchanging enviroment under unchanging conditions is not needed over a larger tire. You are also thinking one dimensionally, tires receive loads in multi directions, not just up and down, front to back.
The only situation I think you really want to concentrate the weight of a car through its tires is in ice surfaces, they use skinny tires with studs in them to aid in traction as opposed to larger wider tires with studs. Ice-prepped rally cars a funny to look at because of this, but they're still uber cool! The same also applies to rally cars in gravel and mud stages, the tires are typical more narrow than tarmac only courses.
Old May 14, 2009 | 12:46 AM
Triple8Sol's Avatar
ok but lets pretend
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
bu villain
19 Inch
Nov 15, 2015 09:23 PM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
wuppiedog
Aug 7, 2015 11:16 AM
nascarbuff17
Jul 16, 2015 10:23 AM
