Quick Tire / VDC Question!
Old May 12, 2009 | 11:59 PM
hanguk9117's Avatar
Hi all,
So this is a quick, hopefully simple question. I currently have a set of aftermarket 19" wheels on my car, with the OEM tires (Front: 225/40/19, Rear: 245/40/19). The rears are balding, and the fronts still have tread. I'm pretty cash strapped right now, and want to only replace the rears. My plan is to set the rears to: 275/35-19, and fronts to: 245/35-19 (when i eventually replace).
Now my question is this. Can I safely run my car with my current front tires: 225/40/19, and just replace the rears to: 275/35-19? Will this be ok? Or will it throw everything off (VDC)? I don't want to replace all 4 tires since the fronts still have tread. I want to use it for all its worth..if possible.
Thanks!
Old May 13, 2009 | 02:46 PM
hanguk9117's Avatar
can any1 help me out?
Old May 13, 2009 | 03:04 PM
redlude97's Avatar
I would suspect VDC will become an issue with that width difference from front to rear along with the difference in grip with the new tires. I do not recommend it at all
Old May 13, 2009 | 03:28 PM
hanguk9117's Avatar
ah...i was afraid of that. thanks for the help redlude, you are the master when it comes to this stuff.
Mry
Mar 3, 2023 01:03 AM
Th611
Oct 27, 2015 03:48 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Wayne9011
Jul 27, 2015 11:25 AM
Soumilg
Jul 18, 2015 12:33 PM
