proper way to install wheel lugs?
Old May 15, 2009 | 01:49 PM
redlude97's Avatar
Originally Posted by eurodre
vinci its been pretty safe for me doing that, even my mechanic suggested that
You get into the car while it is up in the air on a jack?
Old May 15, 2009 | 01:53 PM
eurodre's Avatar
yah i've done that before, it's not as bad as you guys make it.. it's not like im moving around and shaking it, however i wouldnt recomment it on the oem jack, i've always had a floor jack to clarify not the oem crappy one
ShanesG's Avatar
^I do/have, not with just the jack though, but with jack stands sure. Hopefully not just with a jack though Dre!!!
Old May 15, 2009 | 01:55 PM
eurodre's Avatar
ooh i see what you cool kids are saying with just a FLOOR jack, ya man use jack stands
loki05's Avatar
always use jack stands when getting into the car!
redlude97's Avatar
i don't know anyone that uses jackstands when changing wheels, and I don't recommend getting into a car on ANY jack. They all have wheels, hence they can roll
Old May 15, 2009 | 01:56 PM
ShanesG's Avatar
I use pillows for jack stands!
ShanesG's Avatar
If you're worried about rolling, chalk the tires!!
Old May 15, 2009 | 01:58 PM
redlude97's Avatar
I meant the jack, getting into a car can shift the jack and cause it to slip
Old May 15, 2009 | 02:01 PM
ShanesG's Avatar
Gotcha, true, but would take ALOT of effort, assuming you jacked the car up correctly to begin with!
Damn, anyways, we're getting way off topic here. So yeah OP, you've got your answer on page 1!
Old May 15, 2009 | 02:07 PM
j 4 lD's Avatar
you do not need to torque the lugs down with the wheel off the ground. Get them as tight as you can off the ground, lower the vehicle, and then torque them down
Yea. To remove, break the lugs while the wheels is on the ground. Once you jack it up fully remove the lugs. To put the lugs back on, hand tighten them while the wheel is still on the jack stand, and fully torque them when the car is on the ground. Use the star pattern so that everything is tightened evenly. After 50 miles or so, re-torque the lugs.
Old May 15, 2009 | 02:12 PM
j 4 lD's Avatar
Better yet, never get into the car when it's off the ground.
netcbc
Wheels & Tires CDN
Aug 25, 2015 09:42 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
