Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old Apr 25, 2013 | 07:49 PM
  #5581
TGMcCoy's Avatar
Originally Posted by K.C
I'm thinking about getting some CV3's and well to be honest I'm alittle confused about the look I want as far as stance , tire sizing , offset , etc . So to start off I called around and asked about wheel options and I have decided to go with 20's.
( I WILL BE GETTING BC COILS AND A CAMBER KIT) the sizes they gave me for best fitment were
F- 20'' x 9.0 + 32
R- 20'' x 10.5 + 45
As far as the tires go
F- 245/35/20
R- 275/30/20
So my question for the wheel and tire GURU'S are...
1. Does this sound right?
2. What type of stance will I have ? i.e will it make the 4x4 look or slammed etc.
3. Does the tire fitment sound right? I ask because when I plugged the tires into a calculator there was at least a 6mm difference in height .But when I changed the width of the rear tire to a 285 the height for both wheels were the same so why would they tell me to put a 275 on instead ?
Those sound right for a decent almost flush stance. My wife is on some cheapo Stern st-1 20's 8.5 +38 and 9.5+35. Fronts are sunk some, but rears are flush with 275/30 and a fender roll.
I think if you want a decent drop and drivability, then 20's and the sizes you specified would be good for you.
Old Apr 25, 2013 | 07:54 PM
  #5582
TGMcCoy's Avatar
I just saw 08 sedan.. I'm not sure how similar fender clearance to 03-- but the offsets stated seem pretty tame. I think you'll be fine
Old Apr 25, 2013 | 08:10 PM
  #5583
K.C's Avatar
K.C
Thanks for your opinon . Can't understand why the 275 instead of a 285.
Old Apr 26, 2013 | 10:32 AM
  #5584
tsmith1208's Avatar
I currently have a white 2004 G35 Coupe and will soon be purchasing a new set of 19 inch rims. I am leaning towards a rim called Jarama by TSW. Its black with a chrome lip. I would like some help selecting tire sizes as well as some other specs.
Old Apr 26, 2013 | 01:28 PM
  #5585
TORETTO's Avatar
What wheel sizes/tire sizes are available.
Old Apr 26, 2013 | 02:10 PM
  #5586
dragonv's Avatar
What tire size should I get for my fronts? I'm lowered on Z S-Techs. And don't want to rub.
fronts: 20x9, +13 offset
rears: 20x11, +13 offset
This is my daily driver will be doing 275/30/20 Rears (was thinking about doing 255/35/20 but was worried cause it is my daily so wanted more rubber)
Old Apr 27, 2013 | 10:29 AM
  #5587
risingson's Avatar
I'm looking for help with spacers. I'm about to get some new tires thrown on, while I'm at it I'm going to have my coil overs adjusted and get the car realigned. After thinking about it I decided maybe I should try some spacers in the rear but I've never known anything about them until what I've read recently.
I ordered some Ichiba 10mm V1 for my rear wheels. Now that I keep reading more about spacers I'm feeling a little hesitant and I'm not 100% sure I'm going to install them. Some people say that the Ichiba extended studs are an inferior product (is this true?) and I don't want to chance it with something like spacers.
So I'm considering these ARP extended studs http://www.injectedperformance.com/a...for350zg35.htm
And also I read the nismo studs are comparable to these.. but I think they are more expensive?
I have closed ended McGard lugs with locks. Will these lugs work with the extended studs? I know you want 6-8 full turns, I'm not sure how the length (3inch stud+10mm spacer) compares to the stock studs. I don't track my car, are these studs a good idea?
Here are some old pics of my car but this is how it sits now
Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::-fvvib0j.jpg
Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::-wjqrkot.jpg
Old Apr 27, 2013 | 01:08 PM
  #5588
Crack3r's Avatar
Has anyone run 19" wheels in the rear and 18" in the front on a coupe?
Old Apr 27, 2013 | 01:15 PM
  #5589
Plur's Avatar
Please don't do that
Old Apr 27, 2013 | 01:29 PM
  #5590
Crack3r's Avatar
I just lol'd
Old Apr 27, 2013 | 04:53 PM
  #5591
Chuk Brynwood's Avatar
Trying to find tire for Varrstoen ES222 19"
Hi Everyone:
I'm in looking to the above rims but I am not sure of the wall size of the tire (I guess that's what it is called). I know they are staggered 19x9.5 in the front and 19x10.5 in the back. I can't find a tire package online that will go with this set. I was trying to do my own math and I think a 245/35/19 in the front and a 275/35/19 in the back will do. Will that work? Should I go thicker in the back?
I currently have Lexani LSS-10 20x8.5 in front and 20x10 in the back. I know these tires will not fit but one of my other concerns is being able to turn my wheel. 8.5 inches in the front looked tight and everywhere I look it says they fit. Are the Varrstoens a direct fit? I appreciate the feedback. Thx
Attached Thumbnails Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::-photo.jpg
Old Apr 28, 2013 | 04:53 PM
  #5592
buffhulk's Avatar
Been looking can someone tell me what wheels these are
Old Apr 28, 2013 | 08:08 PM
  #5593
TGMcCoy's Avatar
re-barreled steelies perhaps
Old Apr 29, 2013 | 10:40 AM
  #5594
tsmith1208's Avatar
RimSizes
19X8
19X9.5
(2)19X8 (2)19X19.5
Im not sure what rim size to get. right now i have stock 17 inch rims front tire size 225/50 rear 235/50. Should I get staggered when I get the new rims?
Old Apr 29, 2013 | 11:03 AM
  #5595
rhampsterwha2's Avatar
since my350 is gay as hell, borrowing my friends account to get some help specing out some wheels
I DO NOT WANT A HELLA FLUSH SETUP, I WANT A WIDE A$$ TRACK SETUP THAT LOOKS GOOD OFF TRACK
Car: Nismo 350Z, factory brembo BBK, rolled and pulled fenders (15mm of pull), coilovers
Goal: Work VSXX 18" up front and a 19" in the rear, meatyest tire I can get without rubbing issues
something in the lines of:
18x10.5 et??? Rdisk 265/40 or 275/35
19x11.5 et??? O disk 305/30 or 325/30
Looking at the Work VSXX specs sheet I have offset options listed below
19x11.5 O disk (+42 to +17)
18x10.5 R disk (+40 to -48)
maybe +25????
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
