Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old Aug 19, 2022 | 10:40 AM
  #7666
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
You're probably going to have better luck over at the sister site MYG37.COM
This site is for the G35.
Old Oct 20, 2022 | 08:05 AM
  #7667
El.kev's Avatar
08 G35s sedan
New wheels for my 08 G35s sedan
Would 20x8.5 (5x114.3) +35 offset, tires are 245/35R20 fit on a 08 G35 sedan?
Old Oct 20, 2022 | 08:08 AM
  #7668
El.kev's Avatar
08 G35s sedan
New wheels for my 08 G35 sedan
Would 20x8.5(5x114.3) +35 offset tires are 245/35R20
fit on my 08 G35 sedan?
Old Oct 25, 2022 | 09:22 PM
  #7669
tyler ingle's Avatar
just a 05 g35
lowering my g35
okay so i got a 05 g35x sedan and i want to lower it but still have camber in the front and back. people are telling me different things but i’m trying to figure out what else i need to buy except for the lowering springs. somone help me please!
Old Oct 25, 2022 | 10:38 PM
  #7670
Scorpi0's Avatar
This is the whole kit for front and rear. Its what I have on my car. You can probably find it cheaper if you shop around. This will be all you need to bring your camber back into spec.
https://www.tbwperformance.com/spc-f...-for-350z-g35/
Old Oct 28, 2022 | 08:49 PM
  #7671
just a 05 g35
camber
first time having camber but i drive a 05g35X sedan and i want to camber it after i lower it about an 1 1/2 an inch and i don’t wanna have hella camber. what’s a reasonable amount of camber?
Old Dec 15, 2022 | 07:01 PM
  #7672
angel246837's Avatar
G35 sport sedan
I bought a pair of ssr Vienna sovereign. They didn’t come with tires but the previous owner said he was running 265/35/19 but he had an rc350. I don’t have much camber I just lowered my car so I might have to roll my fenders or get more camber so if anyone can help with specs that’d be appreciated! Fronts are 19x9 and Rears are 19x10 with 37 offset all around
Old Jan 19, 2023 | 12:37 PM
  #7673
NastyNate28's Avatar
G35X
New Wheels
Hey I’ve been looking for some new wheels. I’m into stance and have been looking at some Leon hardeitters ritters that have a 0 offset and are 18x11.5 just wanted to make sure these would fit before dropping the money on them
Old Jan 20, 2023 | 10:46 AM
  #7674
Urbanengineer's Avatar
11.5” wheels aren’t going to fit well on stock specs. You will need to make ride height adjustments, camber adjustments, roll and pull fenders, etc.
Old Jan 20, 2023 | 11:23 AM
  #7675
G35X
Yeah that kinda of what I figured. I’m currently on BCs and looking for some new wheels. I would like to get a camber kit for my car. What wheel sizes would you recommend.
Old Feb 3, 2023 | 01:26 PM
  #7676
ChaosZoro's Avatar
Midnight Blue G35 Coupe
(Car is an 04 G35 coupe lowered on bc coils)
Hey I've been looking into some 57cr nismo wheels as well as some other notable ones like the normal gram lights 57cr as well as good ol rpf1's. I was recommended to buy 18x10.5+22 for the rear and 18x9.5+12 in the front. My question is whether or not i can run my stock tires safely until the end of their lifespan without excessive stretching as i just bought a pair of mich ps 4s all around and don't want to not use them as they have maybe a couple hundred miles of wear on em. My stock tire specs are 225/40/18 for the fronts and 245/45/18 for the rear. Thanks for yall's help!
Old May 6, 2023 | 03:47 PM
  #7677
Mrmark's Avatar
G35. New suspension front and rear, ported plenum and manifold, coil overs, spec D ext
Originally Posted by myroncuz
what do you thinks the lowest offset i can go when i get my t1s? i have z stechs and will do 1/2" spring mount mod with 19x9.5 245/35 19x10.5 275/35. ill probably roll my rear fenders.. +17 front and rear? +15? thanks, help greatly appreciated
I just got the same set up on the rear 19-275-35 on a 11 rim. Can I go to a 295? I don’t like the rim sticking out further than the tire. Also is there an issue going with a different brand rear tire? The brand I got don’t make a 295
Old Nov 24, 2023 | 02:09 AM
  #7678
ubaldovarela00's Avatar
blue 2005 g35 sedan static drop
2005 g35 sedan
hey i was just wondering how wide would i be able to go on my 05 sedan looking for specs for big lip wheels looking to run 18x10.5 in front and 18x12 would i be able to? New at the car scene any help would be appreciated!
Currently running a 18x9.5 with 0.5 spacer (don’t know offset) 18x10.25 with 1 inch spacer (don’t know offset)
Old Aug 13, 2024 | 01:10 PM
  #7679
badNbougieG35's Avatar
4 dr sedan awd stock
Sedan
Originally Posted by ShanesG
Hope this helps a lil!
.I went from 18s to 19s rims my g35 is low I always scrap the driveway causing muffler issues what can i do besides stop parking in the driveway my car got hit while parked in the street so i need to do something about this issue
Thanks to anyone who will respond
Old Aug 14, 2024 | 08:06 AM
  #7680
Scorpi0's Avatar
How low is it? I mean if its super low then u probably cant do anything about the scraping.
My car is lowered too and I have to go up and down driveways at a diagonal angle or else my front bumper will scrape.
SIR NUPE A LOT
Sep 18, 2012 02:37 PM
alex_b
Sep 19, 2010 05:28 PM
silvernole12
Jun 14, 2008 06:46 AM
GThIrtYFiZle
Feb 11, 2007 11:21 PM
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
