Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Dec 13, 2013 | 04:24 PM
  #6571
yelnats's Avatar
19x11 et 18 too aggressive for the rear?
Got an 04 coupe and found a set of wheels I want to buy, the specs are
Front: 19x9.5 +20
Rear: 19x11 +18
Is the rear too aggressive? I want the rims to be flush with the fender but are the rears going to be poking out past the fender?
I am currently on stock suspension.
Old Dec 14, 2013 | 10:56 PM
  #6572
TGMcCoy's Avatar
Anybody know the highest offset for a 19x11 / 19x12 stagger setup on stock body with true coil overs?
Old Dec 14, 2013 | 11:22 PM
  #6573
TORETTO's Avatar
Highest?
watchu tryna pull here bic boi
Old Dec 14, 2013 | 11:28 PM
  #6574
Frankieg35's Avatar
Im guessing some fat tyres..
Old Dec 14, 2013 | 11:43 PM
  #6575
TGMcCoy's Avatar
Just curious, mainly for tire sizes. If I do build them wide I don't want them hitting suspension. More likely 10 or 10.5 front, 11.5, 12 rear. Just checking if ya'll know
Old Dec 14, 2013 | 11:50 PM
  #6576
TORETTO's Avatar
19x13 -8 was rubbing my rear true coil collar at -8.0 degrees of camber. Stopped rubbing at -7 degrees.
So 19x12 +4 should be fine, as long as you don't run a lot of camber.
Old Dec 15, 2013 | 12:39 AM
  #6577
TGMcCoy's Avatar
Thanks man
Old Dec 15, 2013 | 12:45 AM
  #6578
TORETTO's Avatar
but why 12. Even I went all the way down to 19x11.5
Old Dec 15, 2013 | 01:00 AM
  #6579
TGMcCoy's Avatar
Yea, I probably will. 12 is a cool number. Lol. I guess if it came down to used inner barrels that are a lot of times pretty wide. When relipping it could get too wide. Mostly was curiosity
Old Dec 16, 2013 | 04:15 PM
  #6580
Big Booty Trudy's Avatar
So 235/255 is okay with 10/11 wide, what about on 10.5/11.5? Too much stretch?
Old Dec 16, 2013 | 05:54 PM
  #6581
TGMcCoy's Avatar
People do it. A lot of the time on 19's people opt to for 235/35/19 and 265/30/19. I did a 235/35/20 on a 10.5 but the 255/35/20 wouldn't sit on the 11.5 rear. They were Nankang though, which fit smaller. Tire brand will play a role
Old Dec 16, 2013 | 10:51 PM
  #6582
ChrisKG35's Avatar
Okay need help on offsets and tire sizes for a mild stretch
F:20" x 9 +15
R: 20 x 10.5 + 25 (Need a 10mm spacer??)
F: 235/35/r20
R: 255/35/r20
Is that too much stretch or just fine?
Old Dec 16, 2013 | 10:52 PM
  #6583
TORETTO's Avatar
No its barely stretched.
Old Dec 16, 2013 | 11:14 PM
  #6584
ChrisKG35's Avatar
Any advice on a sizes for a mild/decent stretch
Old Dec 16, 2013 | 11:27 PM
  #6585
Frankieg35's Avatar
Water the wheel speks??
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
