M45 rims on 2003 G35 Sedan.. question about spacer
Old May 18, 2009 | 03:52 PM
tran2000's Avatar
i just got some m45 rims and the fronts don't fit without a spacer, the question is will 5mm spacer clear the tires from the control arm? i've read that sometimes it does and sometimes it doesn't. also, at what point will i need longer studs? would i need longer studs for 5mm or 5/16 inch spacers?
Old May 18, 2009 | 03:53 PM
j 4 lD's Avatar
From my understanding you don't need longer studs just yet. Anything bigger than 5mm will probably require extended studs. Someone please correct me if I'm wrong.
Old May 22, 2009 | 09:34 AM
FlyingLumpia's Avatar
I would get 15mm all around. Trust me it will look better.
Old May 22, 2009 | 09:39 AM
SDGenius's Avatar
i have 10mm spacers all around w/extended lugs, came w/the wheels... if i hadda buy 'em, i woulda went 15mm.
TWASkyliner
Feb 8, 2020 08:00 PM
Augy
Steering & Suspension
Sep 8, 2015 12:53 AM
Tom_P
Jul 24, 2015 04:05 PM
Chattzx
Jul 17, 2015 11:23 AM
