Question for New wheels on Lowered G
Old May 20, 2009 | 01:19 PM
only1waqas's Avatar
Ok currently i have 19" rays, i dont like how they look (there too inside the fenders.) I will be getting new 19" wheels.
this is the spec of the wheels
19" Staggered Size, Two 19x8.5" (with 20mm offset) 2inch lip and Two 19x9.5" (35mm offset) 3 inch lip 5x114.3mm Lug Pattern
They say it will clear Brembo's. But will it?
2nd question will these stick out or be flush with my fender?
I am currently lowered on tein s tech...
Also this is what i was thinking for my tires setup
245/35/19 - 275/30/19.... will they rub?
thanks.
Old May 20, 2009 | 01:51 PM
EL-EE-ES's Avatar
For the rears you'll need to be in the low 20s or lower...I have 19x10.5+20 and they are flush. With a 9.5 rear look for +15
Old May 20, 2009 | 01:58 PM
redlude97's Avatar
impossible to know if they clear brembos based on specs alone. You need to know the pad height or the specific wheel. You won't rub because those offsets are WEAK. That rear will still be very tucked in. You also need to be running a 275/35/19 rear. I suggest different wheels
Old May 20, 2009 | 03:13 PM
Triple8Sol's Avatar
Yup, pass.
Old May 20, 2009 | 03:14 PM
only1waqas's Avatar
So should i get 19x10 in the rear?
Old May 20, 2009 | 03:34 PM
redlude97's Avatar
that would once again depend on the offsets
Old May 27, 2009 | 01:59 PM
only1waqas's Avatar
What offsets to look for with 19x8.5 in front and 19x9.5 rear? to be flush i saw that somebody said +15 for rear but how about front?
Old May 27, 2009 | 02:08 PM
ShanesG's Avatar
^At LEAST +0
Old May 27, 2009 | 02:18 PM
only1waqas's Avatar
Originally Posted by ShanesG
^At LEAST +0
so these are the type of wheels i should be looking for
19x8.5 +0
19x9.5 +15
Old May 27, 2009 | 02:20 PM
ShanesG's Avatar
+0 front and rear!!!
Old May 27, 2009 | 02:33 PM
only1waqas's Avatar
thats wierd but i usually see most wheels with some kind of offset mostly around +20-30....
Old May 27, 2009 | 02:55 PM
ShanesG's Avatar
Cause they are wider. The wider the wheel gets the higher the offset is gonna be to sit the same!
Even +20-30 is still weak offsets for the G, even with wider wheels!!
Old May 27, 2009 | 11:49 PM
eurodre's Avatar
mmm throw on some negative offsets
Old May 28, 2009 | 12:16 AM
j 4 lD's Avatar
ROFL.
Just as a reference, here is a picture of what offset actually is, for those who don't know. Negative offset would require wide *** wheels with a deep dish look (huge lip).
Obviously there are varying degrees of offset, but this diagram gives you an idea of how it works. I know many people that know exactly the perfect offsets for their car, nice fitment, etc, but have no idea what offset actually is.
Old May 28, 2009 | 12:19 AM
eurodre's Avatar
Originally Posted by j 4 lD
ROFL.
oh really? 9.5 -14 can get you about a 4 inch lip and 10.5 -8 gives you about 5 or so
point being, doesn't have to be wide *** wheels
