alignment chart, camber kit, and tires...
Old May 29, 2009 | 12:08 AM
DefJux921's Avatar
so i lowered my car ('06 6mt coupe) about 2.5 years ago on 350z espelir gt's.. attached is the alignment chart, which at the time i had assumed was close enough - but after lookin at my front tires recently thats apparently not true. so i was considering the cusco front a-arms... i also saw a kit available for $110 more that has "intense rear camber" kit which i've never heard of.
http://www.g35parts.com/9083/osc/pro...roducts_id=664
i wanted to kno if anybody had experience with this, or if i even need the rears (if you look at the attached alignment chart my rear is very close to spec)
also, on a side note - wut yall think about nitto nt05's? its time for new tires and i want to stick with the oem 19 size... i live in southern cali where its mostly dry weather...
Old May 29, 2009 | 01:09 AM
ea_rsx's Avatar
I am actually looking into buying front and rear camber kit because I just picked up a new set of coilovers. From my searching I have found the following kits:
SPC - front priced around $350 to $380 and rear $150 to $180 (best bang for buck and a good design for adjustments)
SPL - front priced around $500 (recommended by people on the forum)
Kinetix - front priced around $200ish range and rear $120 - $150(cheaper up have been known to crack at the welds)
Cusco - front priced around $400 and up (adjusted with 6 allen screws {could be the only issue})
Ksport - front priced around $350
Ichiba - front priced around $300
there is a bunch more... I think I am going to buy the SPL's
Old Jun 12, 2009 | 04:24 PM
DefJux921's Avatar
well i think im gunna go with either spc, spl, or ichiba.. i can't decide... i hear horror stories of some of these kits breaking causing catastrophic failure which freaks me out..
does anybody know what ideal camber settings are for handling?
Old Jun 12, 2009 | 04:28 PM
redlude97's Avatar
handling and tire wear are mutually exclusive. Pick one
Old Jun 12, 2009 | 04:46 PM
ea_rsx's Avatar
I would do SPC one of the better brands and not to expensive in comparison to others on the market.
Old Jun 12, 2009 | 07:21 PM
DefJux921's Avatar
my latest post didn't mention anything about tire wear - my question was "does anybody know what ideal camber settings are for handling?" - i kno some negative camber is good for cornering, but how much negative camber is my question
Old Jun 15, 2009 | 03:40 PM
Triple_X's Avatar
I got an spc rear camber kit for sale if you are interested..
here is the link
http://myg37.com/forums/brakes-suspe...brand-new.html
zoop425
Mar 29, 2016 05:51 PM
G4ORCE
Aug 22, 2015 01:16 PM
NohoG35revup
Aug 22, 2015 12:13 PM
socalg35x
Aug 7, 2015 09:36 AM
nascarbuff17
Jul 16, 2015 10:23 AM
