wheel spacers
wheel spacers
What's up guys?
I'm ready to buy some wheel spacers, but I cannot make up my mind on the sizes. I've 05 G35 Coupe with OEM 19" rims, stuck suspension.
what sizes shall I go with?and what brand?
Thanks much for your help and input.
i also recommend 25mm all the way around. Here's my post with pics of my car when i had them.
https://g35driver.com/forums/brakes-...d-springs.html
30 offset for the front
33 offset for the rear
so if you add your 25 spacers all around and keep your oem size tire then do it.
if you change your oem tire size to 245/35 255/40 and still use 25mm spacer all around
your front tires will look more flush than the rear
so I went with 20/25 so now my rears look more aggressive than the fronts.
my opinion
my opinion
can someone please explain to me what spacers are and what they do i just bought an 03 coupe automatic with the oem 18 and wanna upgrade 1 inch drop all around i was thinkin tien s tech springs with stock shocks right now keeping the 18 on 19 upgrade later. but i hear talk about spacers constantly can some one explain or show me the differences with or without spacers
I'm on Z S Techs w/springmount mod. And that pic was before the springs settled looks better now.
