Toyo tr-1 vs Bridgestone Pontenza Re-11
Old Jun 9, 2009 | 05:03 PM
TwilightBLUES's Avatar
deciding between these two tire choices. the re-11 so far have caught my eye through reviews and friends experiences. the toyos are 100 dollars cheaper, which is not too much of a concern, just want to know which is a better option.
please anyone who has used either applications on similar setups let me know
keep in mind:
running 400 hp
in 245/35/19 & 275/30/19 sizes
main concern is putting power to the ground and cornering
live in cali so dry conditions are more important
thanks guys for the input.!
Old Jun 9, 2009 | 05:35 PM
mIKE's Avatar
Wow.
This is not even a comparison. If you need grip, RE-11 is the way to go.
The T1R is a FK452 competitor. The R1R, and RT615 are competitors, both of which are outdated designs, and not quite competitive with the RE01-R, which was phased out and replaced by the RE-11.
With 400hp, cost should not even be a factor in your tire choice.
You're lucky the RE11 comes in 19's... the RE01R only came in 18's =(
Old Jun 10, 2009 | 02:41 AM
captainduy's Avatar
RE-11 by bar. Like the above post you can't even compare the two tires.
Old Jun 11, 2009 | 12:50 AM
j-velocity's Avatar
275/30R19 is not the right size for G.
you need 275/35R19.
Old Jun 11, 2009 | 05:07 AM
Skaterbasist's Avatar
Retired SuperMod
You're comparing apples to.... watermelons.
The T1R are nice tires for a DD car. They are great all around tires. But the RE11's are just far superior when it comes to grip and performance for hard driving.
Old Jun 11, 2009 | 05:58 PM
cool thank you guys i thought the same but a friend of mine was trying to pursue me to buy the toyos. i already ordered the re-11's about two days ago and they should be in tommorow.
velocity - why do you say the wrong size? i have been running those same sizes for several years now. What would be the advantage to running the 35?
Old Jun 11, 2009 | 06:03 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
I'd vote for the B-Stone as well. Tested them two weeks ago and that tire was amazing.
Old Jun 11, 2009 | 06:29 PM
great to hear, i cant wait to test them out myself!
Neal, question for you, is it bad that i am running in the rears 275/30/19 as opposed to 275/35/19
Old Jun 11, 2009 | 06:33 PM
PLATINUM SPONSOR
Going to be an inch shorter than recommended. Might play with VDC and speedo a bit. They do make load carrying capacity, however.
Old Jun 11, 2009 | 06:39 PM
so i should, recommended, run 245/35/19 fronts and 275/35/19, even though due to my sc my vdc is always turned off.
Old Jun 11, 2009 | 06:41 PM
PLATINUM SPONSOR
That's what I would do.
Old Jun 11, 2009 | 11:45 PM
j-velocity's Avatar
I have ran 285/30R19 on my car for several months and I absolutly hated it.
The tires are 1.2" shorter than what supposed to be (stock size is 26.7", 30 is 25.6", 35 is 26.6")
Both speedo and odo meter are wrong.
And the low profile gave me a really rough ride.
The 35 profile is the proper size for 275/R19 tires.
Old Jun 12, 2009 | 06:41 AM
i c thank you velocity for the needed info. The tires are supposed to come in tomorrow, so i will definitely see what i can do.
jilljann1
Jul 21, 2020 08:12 AM
tkuntz
20 Inch
21
Sep 26, 2016 09:13 AM
inexorable
17 Inch
Sep 24, 2015 10:43 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
derres
Aug 28, 2015 03:27 PM
