Will BBK fit on 20" T1S with +15offsets???
Old Jun 16, 2009 | 12:34 AM
Mr_pharmD's Avatar
I need to find out will the Alliance 8pistons Front and 6 pistons Rear fit on 20" Work T1S with +15 offsets all around (Front 9.5 R and rear 10.5 O)?
The alliance calipers are 139.7mm (5.5") wide and I believe they are smaller then the rotora 8 pt calipers if that makes a difference.
Also, I know the alliance BBK will fit these rims and offsets for sure:
1. GT7 20X9.5 +23 / 20X10.5 +26
2. CE28N 19X 9.5 / 10.5 +22 all around
3. GT30 20X9.5 +23 / 20X10.5 +24
Old Jun 16, 2009 | 01:32 AM
vq35dedriver's Avatar
buy them and try it. just in case it doesnt buy some spacers quick fix
Old Jun 16, 2009 | 01:53 AM
ttrank's Avatar
Grocery getter
How close to some of those others are they? Based on the offset and wheel face style it's going to be very close and I would bet they won't.
Old Jun 16, 2009 | 02:12 AM
redlude97's Avatar
impossible to know without knowing what face is being used
Old Jun 16, 2009 | 02:21 AM
rookie's Avatar
Isn't the R and O disk the face?
Old Jun 16, 2009 | 02:26 AM
redlude97's Avatar
yep, totally didn't read that part
Old Jun 16, 2009 | 02:28 AM
rookie's Avatar
hehe, I'm not a wheel ***** so I don't know the different faces from work and the others like that.
Help the brotha out!
Old Jun 16, 2009 | 02:48 AM
jalilig35's Avatar
well r disk is for bbk fitment, so yes it should fit, the rear im not sure
Old Jun 16, 2009 | 03:20 AM
Mr_pharmD's Avatar
aren't u running the O dish in the rear also with 4pot?
Old Jun 16, 2009 | 03:29 AM
Mr_pharmD's Avatar
I found a thread where jjyellow was running 20X9.5 +7 R and 10.5 +0 O with his rotora but I'm not sure if those are 8pot/6pot. Can anyone tell or know? If rotoras fit at such a low offset shouldn't I be good at +15 all around?
Old Jun 16, 2009 | 03:54 AM
ShanesG's Avatar
They should fit easy, if I remeber correctly alliance calipers are not as wide as rotora.
Old Jun 16, 2009 | 04:05 AM
KurtayKurt's Avatar
the wheel ***** god has spoken!
Old Jun 16, 2009 | 11:35 AM
eurodre's Avatar
you can also try an offset calculator to get an idea of the inner clearance from your current position, that might help
Old Jun 16, 2009 | 11:51 AM
ShanesG's Avatar
^That wont matter for caliper clearance!
Old Jun 16, 2009 | 11:58 AM
eurodre's Avatar
edit: nvm do what shane says
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
TurTLe*
Sep 29, 2015 01:43 PM
Claudiu
Sep 26, 2015 01:04 PM
