Will a 19x10 inch wide wheel hit the fender?
My coupe is not lowered...yet. But I was wondering if anybody has this configuration and has problems with the wheels hitting the fenders (19x9 and 19x10 with 235/35 and 275/35 tires).
G's Up...
G's Up...
Re: Will a 19x10 inch wide wheel hit the fender?
If you keep the tire size as you have suggested and keep the offsets no lower than +22, I think you should be fine. For the front, you should actually go 245/35.
or even 255 on a 9" wheel. I have 245/35's on a 9" wheel and it would look better with a 255. The stagger between the front and rear would decrease but would still be well within reason.
I also wanted to know this...am i correct to assume that if i go with the same setup (19x9 and 19x10 with 245/35 and 275/35) that it will not rub with the stock susp.....Another option i have is a 9.5 in the front and a 10.5 in the rear would i be able to get away with that?
