Offset Question
Old Jun 28, 2009 | 08:13 PM
DjFergi's Avatar
Offset Question
Hey Guys,
I did some searching around and couldnt seem to find a definitive answer.
I' m thinking about jumping on a set of wheels.
The specs are as follows:
18x8 with a 45mm Offset.
I know this will be fine with my stock suspension setup. However, I plan on dropping the car on a z/coupe setup.
Will I have any issues with rubbing seeing as though i'm looking at a very conservative drop?
Any help or direction would be greatly appreciated.
Thanks,
Fernando
Old Jun 28, 2009 | 10:12 PM
Triple8Sol's Avatar
That fitment is weak as hell. You should keep looking.
Old Jun 28, 2009 | 10:16 PM
DjFergi's Avatar
Im not looking for an agressive offset. I don't want to have to roll the feders. I'm not very concerned with if the wheels are going to sit flush.
Just looking to make sure that I wont have any trouble when it comes to dropping my G.
The stock 07 G35 18s are 18x7.5 with a 45mm offset. I've seen a few members put these on the 03 - 06 G35 sedans. Looked pretty good IMO.
Old Jun 28, 2009 | 10:20 PM
EL-EE-ES's Avatar
if your not worried about it sitting flush then they will fit fine
Old Jun 28, 2009 | 10:22 PM
DjFergi's Avatar
Thanks man. Appreciate the help.
Old Jun 28, 2009 | 10:24 PM
Triple8Sol's Avatar
This setup is not only "not aggressive" it's worse than stock. Why would you do that?
Old Jun 28, 2009 | 10:26 PM
DjFergi's Avatar
As i stated above, im not worried about the wheels sitting flush. Just want an upgrade from my OEM wheels.
I currently have the stock 17" 6 spoke wheels.
Do you have a recommendation for an 18" wheel that will not need to have the fenders rolled once a install my suspension setup?
Old Jun 29, 2009 | 01:05 AM
eurodre's Avatar
if you want an upgrade get the coupe 19s
Old Jun 29, 2009 | 06:18 AM
Triple8Sol's Avatar
It's not an upgrade if it looks WORSE than stock, is it...
Old Jun 29, 2009 | 06:25 AM
alphamatt's Avatar
a wheels fitment can change a cars appearance entirely, get a wheel that sits nice and flush and you wont regret it later
Old Jun 29, 2009 | 07:54 AM
DjFergi's Avatar
I guess Im just not understanding the point of having to get an aggressive wheel offset.
Thanks for the help guys.
Fire0nic3
Aug 31, 2015 03:18 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
reaper76
Aug 5, 2015 10:13 AM
