17inch clear brembos?
Old Jul 13, 2009 | 03:49 PM
Balkranjit's Avatar
Hi there, i found a listing for a set of winter tires. I have stock 18 inch rims with brembos.
The listing is for a set of 2005 17 inch rims with winter tread.
I couldn't find anything from previous posts but im sure someone has asked already.
If someone knows please let me know if their will be a clearance issue with the brembos.
thank you
Old Jul 13, 2009 | 04:03 PM
redlude97's Avatar
OEM Coupe 17's usually need a 3mm spacer to clear, some people have gotten them to clear without a spacer but it will be very close
Old Jul 13, 2009 | 04:33 PM
Balkranjit's Avatar
sorry just to clearify, 3 mm would be minimum spacer needed?
I did find 5 mm on ebay just for reference.
But i would rather go with the 3 mm if the orginal lugs would still fit or would i need new ones? but if needed i dont mind going thicker.
thanks for your quick reply.
3 MM minimum?
would OEM lugs still fit?
would bigger than 3mm be needed?
Old Jul 13, 2009 | 04:40 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
Here's my 03 6MT on 17" snow pack back in the day. No spacers needed.
Attached Thumbnails 17inch clear brembos?-wheel-1.jpg   17inch clear brembos?-wheel-2.jpg
Old Jul 13, 2009 | 05:02 PM
Balkranjit's Avatar
wow, looks kinda funny with snow tires and small rims eh?
thanks for the input again,
just to clearify any 17inch rim would fit, these ones im looking at are off 2005 g35 dont know about yours. dont know if it would make any difference.
i attached the pics
Old Jul 13, 2009 | 05:04 PM
PLATINUM SPONSOR
Hey, function over style for winter lol
Old Jul 13, 2009 | 05:05 PM
redlude97's Avatar
3 MM minimum?
Only 1-2mm of clearance is actually needed. 3mm is the smallest spacer you can find though, and can be used with OEM studs/lugs. With 5mm spacers, new longer studs are recommend. Your wheels don't look like the OEM coupe wheels though so I don't know what the clearance is like on those
Old Jan 22, 2010 | 02:57 PM
racingby's Avatar
did anyone try to wear r16 on brembos? rear wheels
Old Jan 22, 2010 | 02:59 PM
dubbedown's Avatar
i imagine 17s with the right offset would clear...
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
