Axis pentas
Axis pentas
I was interested in picking up a set of these wheels. Leaning towards the 20" ones. I saw a thread somewhere saying the 20's fit better than the 19's. Is this true? I dont want to use any wheel spacers if I dont have to. Any input?
i suggest searching around to see what kind of offsets would match your drop height so that you won't need spacers. If you don't know offsets search for that as well. It's a pretty long road ahead
as for 20s fitting better than 19s, a wheel with carefully searched offsets and specs should fit in nicely despite being a 19 or a 20. Just don't go over 20's
also tires for 18s and 20s are relatively cheaper than for 19s so keep that in mind
the 19" pentas have horrible offsets. if you don't want to run spacers then the 20" pentas are the way to go. Or you could just choose a better wheel with good offsets in a 19" size
sinasajadi
Aug 26, 2015 04:12 AM
