steering wheel vibration at high speeds, only front wheels off-balance?
Old Aug 12, 2009 | 09:39 PM
HXS's Avatar
HXS
so my steering wheel vibrates at about 80 mph.
should i re-balance only front 2 wheels or all 4?
Old Aug 14, 2009 | 01:40 PM
BRONX_BALLIN's Avatar
Am more then sure you have a bent wheel..When you car goes to the right or left then they need to be balanced.
Old Aug 14, 2009 | 03:54 PM
blackonblack's Avatar
I have the same problem. The dealer told me I needed to get them balanced but they didnt say if just the front 2 or all 4 and I forgot to ask :/.
Old Aug 15, 2009 | 06:59 PM
HXS's Avatar
HXS
i just got all 4 balanced and no more vibration
no wheels bent.
Old Aug 15, 2009 | 07:02 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
You're kidding right? Balance doesn't cause your car to track, the caster in your alignment does.
If you have high speed vibrations you need to have the assembly balanced. If you have aftermarket wheels and don't have hub-rings, that can be another culprit.
-GP-
You can do just the front 2, but you might as well do all 4 since you're already there and the car is already in the air.
-GP-
Old Aug 15, 2009 | 07:08 PM
mesias's Avatar
Road Force Balance? Is it real?
Old Aug 15, 2009 | 07:15 PM
Is it real? haha, yes, it's very real. I performed a road force balance on a car yesterday. The tire was marginal to start with and had a pretty bad hop with 24lbs of road force. After the ride matching it had no hop and only 12lbs of road force. It can also detect if a tire is defective.
-GP-
Old Aug 15, 2009 | 07:21 PM
mesias's Avatar
The dealer charge me once like $70 for a Road Force Balance a while back. It was the only period of time when I could drive with my stock 17" without vibration!
rezendvous420
May 31, 2020 01:26 PM
Xfactor
Dec 1, 2019 12:52 PM
rping
Jul 26, 2015 09:53 PM
TheefrshstVQ
Jul 26, 2015 09:37 PM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
