Extended Studs...Quick Help
Old Sep 15, 2009 | 10:25 PM
The Stimulation's Avatar
I have H&R 15MM spacers with extended bolts but they are probably going to be too much for my setup so I'll be goin with Eibach 10mm spacers. Both require extended studs...
As mentioned I have the studs from the 15mm H&R set, but will they work for the 10mm Eibach spacers or will it be too long?
Old Sep 15, 2009 | 10:41 PM
GLuXuRy's Avatar
do you have open ended lug nuts ? if so dont worry
if you dont, can you match up the studs with the wheel off the car ? 5mm isnt much
Old Sep 15, 2009 | 10:58 PM
I'll be going to my friends house and he has open ended lugs and an impact gun. I just didn't want to go through the trouble and end it end up being a tad too long and having to put the stock ones back on.
Old Sep 15, 2009 | 11:12 PM
GLuXuRy's Avatar
dont impact your baller wheels !!! do that **** by hand =) i run 10mm spacers with extended studs and closed end lugs .. i have no idea how long they are though .. good luck with the install
Old Sep 15, 2009 | 11:54 PM
Oh heck no, I meant using the impact gun on getting the bolts on with the open ended lug nuts. I guess only thing i can do is just try it out..or I'll call Eibach and find out, was just seein if anyone on the forums knew the answer.
BTW, got any pics of your ride? Couldn't find any other than your avatar on VSC.
Old Sep 16, 2009 | 09:29 PM
XDR-V35's Avatar
im running 60mm nismo studs with a 5/16" spacer and ive ran them with no spacer at all.. they will not affect anything by being too long besides possibly appearance, my wheels have a deep lug well and you cannot notice the difference, w/o the spacer there is probally 1/2" of stud past my lug.
Old Sep 16, 2009 | 09:47 PM
GLuXuRy's Avatar
how did the studs go ??
my ride is super basic, just wheels and coils, lil **** here and there, saving for some Works in Dre's fitment, then ill have some clearence for front bumper, sides and exhaust
but for now this is how i roll ... wheels are pretty sunken in
seagrasser
May 3, 2022 09:43 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
the93owner
Oct 4, 2015 09:40 AM
leo38cheng
Sep 29, 2015 05:43 PM
