low tire pressure light blinking.?
Old Oct 4, 2009 | 05:44 PM
DanielsG's Avatar
i just installed my GFG's and have put about 200 miles on them. today all of a sudden, the low tire pressure light was blinking. When i arrived home i checked the pressure and it was fine. What could this be? were the indicators in the stock wheels? I already tried turning the car back on and it just flashes a bunch of times and then stays lit.
Old Oct 4, 2009 | 06:05 PM
Calvin's Avatar
Overglorified Altima
i'm guessing they didn't transfer the tpms into the new wheels.
Old Oct 4, 2009 | 06:12 PM
Laurabella99's Avatar
Yes--the indicators were in the stock wheels. $200 a piece valve stems.
Old Oct 4, 2009 | 07:22 PM
DanielsG's Avatar
so all i have to do is trasnfer them?
Old Oct 4, 2009 | 09:02 PM
Yes-'just' swap them to the new ones. MUST use a rebuild kit. MUST know what you're doing. Or take it to a shop & have them do it for about $100. If you want instructions, know kinda what you're doing, if you just need a LITTLE help, lemme know & I'll have hubby get on & type out instructions for you.
Old Oct 4, 2009 | 09:48 PM
baseballkid25b's Avatar
or isn't there a way to just shut the light off b/c i have the same problem I just put new wheels on and it still on I just haven't done anything about it lol
Old Oct 4, 2009 | 10:00 PM
DanielsG's Avatar
i dont know if there is a way to shut it off. but i think replacing the sensors to the new wheels will be beneficial, especially running 20's with low pro-tires. Laurabell, could you be so kind as to help me along with that process. Maybe your husband can write a step by step. This will will be helpful to the forum. also whats a rebuild kit? expensive?
Old Oct 5, 2009 | 10:00 AM
hey danielg35 what part of boynton beach do you live in
Old Oct 5, 2009 | 10:07 AM
Dubi2087's Avatar
If the sensors are in the factory wheels with the tires on you will not be able to do it yourself. Find a Discount Tire store by you, reason why i say Discount is because I work there and they have the proper tools to swap them (rebuild kit and the torquing tools for the valve stem and the lock nut). They will also reset the sensors for you (if you need it).
Old Oct 5, 2009 | 07:45 PM
DanielsG's Avatar
i called my buddies shop that put the tires on. he may not know but, he said that in order to fit the factory pressure sensors on my wheels, i have to drill in the barrel... i find that highly unlikely. he said the reason was because the valve stems are 90 degrees aluminum, and come through the spokes. is this bologna?
Old Oct 5, 2009 | 07:46 PM
DanielsG's Avatar
i live in canyon lakes-
Old Oct 5, 2009 | 07:51 PM
EL-EE-ES's Avatar
if you have 90 degree valve stems read this
https://g35driver.com/forums/brakes-...-work-etc.html
this is what i did on my work wheels
Old Oct 5, 2009 | 08:44 PM
DanielsG's Avatar
cool. you did them your self?
Old Oct 5, 2009 | 08:58 PM
EL-EE-ES's Avatar
i put them on myself before i had tires mounted
Old Oct 5, 2009 | 09:36 PM
alright well live in lake charleston kinda near but know some people that live in there maybe ill see you around
