Tokico Spec D on eBay
Old Aug 12, 2004 | 05:24 PM
av8r's Avatar
There is a set of 2 shocks and 2 struts on ebay right now. I thought these weren't available yet.
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
04' Sedan 6MT Silver/Graphite/Premium/Aero/HuperOptik/XM
Z-Tube / Stillen- Sways, Airbox & Grounding Kit
19x8.5/9.5 Hiros / S-03s 245/40 & 275/35zr19
04' Coupe Suspension OTW
Old Aug 12, 2004 | 05:46 PM
Gsedan35's Avatar
Re: Tokico Spec D on eBay
No, they are avaliable now. Their's a reseller on my350Z.com selling them for $649. Heck, at $499 shipped with the ebay ad you posted, that's a great deal!
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
Old Aug 12, 2004 | 07:53 PM
dklau33's Avatar
Wait, these ones for sale say they are for the sedan or coupe. But isn't the stock sedan shocks and struts taller than the ones for the coupe? Or is Tokico not making a separate taller set for the sedan and a shorter set for the coupe? Are they just making one set for both?
04' G35S 6MT Ivory Pearl, Willow, Premium
Z-Tube / NFC Y-Pipe / Custom Mid-Pipe / 350 EVO Rear Sway/ '03 350Z Shocks and Springs<P ID="edit"><FONT class="small"><EM>Edited by dklau33 on 08/12/04 04:55 PM.</EM></FONT></P>
Old Aug 12, 2004 | 09:30 PM
av8r's Avatar
I was wondering the same thing. Anyone?
Old Aug 12, 2004 | 11:01 PM
Gsedan35's Avatar
One set for both, you won't see a taller version for a sedan, it's a performance shock that will be picked up by buyers largely running them on lowered vehicles. Tokico does not catalog a sedan fitment to my knowledge, but why should they, the suspension's are the same everything else that matters is the too hair splitting close to matter. For that matter they might have used even shorter piston rod length's then coupe/Z lengths.
Edmund Burke
G35 6mt
Old Aug 13, 2004 | 02:08 AM
dklau33's Avatar
Interesting. Thanks for the reply. So using the D-Specs with the stock sedan sport springs would probably be a bad idea? Would probably want to use at least the coupe or Z springs I'm assuming if you want to stick to stock?
Old Aug 13, 2004 | 12:13 PM
user 4560487's Avatar
"So using the D-Specs with the stock sedan sport springs would probably be a bad idea?"
I'd like to know that also... If it is, what is a recommendation for shocks that work well with otherwise stock sedan???
Thanks!
Mize
Silver 03 6 Speed Sedan/Willow/Premium
Wish List:
18x8 SSR GT1 with 245/40/18 Kumho Ecsta MX
Springs/Shocks/Sway Bars
http://www.AutomobileFanatic.com
Old Aug 16, 2004 | 01:12 PM
GoSooners's Avatar
I am the one who pulled the trigger on those for my coupe =). I'll let you know how it goes once I put them on. I'm currently on RSR springs now.
Black on Black 5AT Coupe, Navi
Falken Koblenz 19x8.5 F 19x9.5 R
Falken FK-451 245/35 F 285/35 R
HKS Legamax Exhaust
350Z Duct
Stillen Hi Flow
7 Wire Hypergrounding Kit
Old Aug 16, 2004 | 09:21 PM
Gsedan35's Avatar
No, using the D-specs on a stock sedan,or with lowering springs, or maybe coupe/Z springs would be a great idea. Koni's would be a great idea too. The draw for the Tokico's is that they are double adjustable. Though if you plan on getting creative, as in stiffer springs then you can currently get with G or Z lowering springs, I would side with the Koni's, staying well below what Koni say's is the max stiffness they'll handle. But that's a whole different matter.
Edmund Burke
G35 6mt
Old Aug 27, 2004 | 02:18 PM
av8r's Avatar
I just pulled the trigger on these too! You can get either the z spec or G spec. The seller on eBay, jdmwerks says, that the only difference is the valving. They are going for $499 shipped to the 48.
Coupe Suspension
Old Aug 28, 2004 | 01:23 AM
GoSooners's Avatar
I got mine today. I misplaced my digicam somewhere but I'll try to have pics of the shocks before I mount them soon. Rebound AND compression is adjusted simultaneously, not separate. The adjustment screw can be turned 8 complete revolutions from full hard to soft. I guess when they say it's "16 way adjustable," they mean half a revolution.
HKS Legamax Exhaust
350Z Duct
Stillen Hi Flow
Old Aug 28, 2004 | 10:57 AM
av8r's Avatar
I think it means that you have 8 settings of compression and rebound which equals 16. At least thats what I can tell from their website. I was hoping that you could adjust them seperately. I guess this means that in most adjustable shocks, only the compression can be adjusted? Also even though there are 8 revolutions of the adjustment ****, Tokico says that you can turn the **** to any position in between making for an infinite amount of settings.
Here is their link to the site and another to a graph showing the adjustments:
http://www.tokicogasshocks.com/car/d-spec.html
http://www.tokicogasshocks.com/car/D-spec_graph.htm
Coupe Suspension
Old Aug 30, 2004 | 01:45 PM
dklau33's Avatar
Anyone know when the whole suspension kit including the springs are coming out? I wonder what the spring rates are and if they are progressive or linear.
prinny
Nov 22, 2015 11:07 PM
nanobotking
Oct 8, 2015 08:40 AM
Learned Hand
Oct 1, 2015 09:02 AM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
awalle01
Sep 28, 2015 12:36 AM
