TPMS Sensor Corrosion
Old Oct 17, 2009 | 10:37 PM
manbart's Avatar
I went to have my snow tires mounted on my 2004 G35X today at local tire place and was told my TPMS sensors had corrosion and they couldn't get them off without risking breaking at least a couple of them. They say I should take it to Infinity dealer because they will have the right sensor's. I have extended warranty and hope it will cover replacement of sensors. I think it should.
Tilf
Old Oct 18, 2009 | 10:38 AM
Q45tech's Avatar
Always make sure the air you use to inflate tires has low moisture content.
Old Oct 18, 2009 | 10:51 AM
manbart's Avatar
That's good
Tilford
Old Oct 19, 2009 | 12:31 AM
Neu Era's Avatar
They will corrode quickly without having the caps on. Also road salt.
Old Oct 19, 2009 | 07:08 AM
manbart's Avatar
Road salt all winter here in Massachusetts.
Old Oct 19, 2009 | 01:41 PM
Neu Era's Avatar
Make sure that you use plastic valve stem caps, because the metal ones will get stuck as well as the valve core.
Old Oct 22, 2009 | 06:31 AM
mzpnai's Avatar
I have same problem on my 2007 g35 coupe for the past 4 days now. I brought it to Infinity but they juz lowered the PSI to 35 and told me to drive it around, but it never went off
Old Oct 22, 2009 | 07:07 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
We do have sensors if you need a replacement
Old Oct 28, 2009 | 04:06 PM
Neu Era's Avatar
Local costco has them too, for our cars its only $62 per sensor. I work at the one in sterling va
Old Nov 21, 2009 | 05:10 PM
jimmyc13's Avatar
Costco sells them? Wow, would have never known that. So they sell TPMS's but are no longer going to stock Coca Cola products.
Old Nov 24, 2009 | 06:40 PM
Blue Dream's Avatar
I drove ttrank's car solo
How messed up is that??
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
vamarris
Sep 26, 2015 12:56 PM
