wheel spacers and wheels not having recession in back
Old Nov 5, 2009 | 07:33 PM
hyperlite21's Avatar
did a search someone had asked this but it never got answered, i want to get 20mm spacers but i dont know if i need to get the ones with extended lugs or the ones with built in lugs. my wheels currently dont had the recessions in the back to the existing lugs can go into it. All i need to know is that if i get ones with built in studs will a 20mm spacer fit over the existing lugs deep enough so i dont need to get extended lugs. not sure if this exactly makes sense....thanks
Old Nov 5, 2009 | 07:56 PM
-LangsurG35-'s Avatar
funny because i find myself in the same boat....mine dont have any room in the back and i tried on the 10mm i have and it wont fit...
Old Nov 5, 2009 | 07:59 PM
ya i knew anything under 15 would be a problem but 20 for my wheels will be just about right but i dunno if there gonna work
Old Nov 5, 2009 | 11:11 PM
anyone???
Old Nov 6, 2009 | 04:53 PM
asdfghjkl;
Old Nov 6, 2009 | 05:02 PM
Kris79's Avatar
battle froggy
u gotta go with h&r and change the studs.
Old Nov 17, 2009 | 03:52 AM
koG35ko's Avatar
yup, Kris79 is correct.
I bought 15mm and 20mm spacers with adapters and had the same problem.
was down to either shaving the stock studs or digging "grooves" in the back of my Racinghart C4s. neither option was what i really wanted to do.
then i did more research and found i could have avoid this problem with H&R DRS style wheel spacers.
just purchased the H&Rs, and will have them put in this week.
cant wait!!!
Old Nov 17, 2009 | 04:02 AM
ShanesG's Avatar
You have to get at least 25mm if there are no opening in the back of the wheel. 20mm the studs will stick out a lil and wont sit flush with the spacer
Old Nov 17, 2009 | 07:22 AM
jwrape's Avatar
I just installed mine yesterday
https://g35driver.com/forums/wheels-...ifference.html
Fortunately for me, my wheels have slots for the longer wheel studs to fit inside the wheel. But you can see my pics in my thread.
Old Nov 17, 2009 | 03:07 PM
OCG35's Avatar
25mm H&R DRM here for sale - if anyone is interested...
Old Nov 17, 2009 | 03:10 PM
oyoquem's Avatar
20mm will stick out a few mm. I had to grind mine down with an angle grinder to get them to fit. You should not have any problems if you can go with a 25mm though
Old Nov 17, 2009 | 03:27 PM
O HELLA OEM's Avatar
So if the back of any rims have indents
behind it , ichiba v2 hubcentric spacers will fir
with no problems , correct ?
Old Nov 17, 2009 | 04:00 PM
ShanesG's Avatar
^For the most part yes, i'd have to see, cause i know the back of some rins have the openings but still wont fit the lug in there!
Old Nov 17, 2009 | 04:26 PM
The Stimulation's Avatar
Mike PM me info and links. Got a friend that MIGHT be interested. Not sure if he wants 25's or 30's but I can pass the info onto him.
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
apintojr
Jul 23, 2015 10:52 AM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
