2 sets of wheels? 2 sets of TPMS?
Old Nov 17, 2009 | 09:29 AM
gian13's Avatar
checked the FAQ's and this question was left unanswered.
"Can I buy a second set of sensors for my other wheels and get both to work on my car?"
Basically i just ordered a set of 18's and I was wondering if I can have 2 sets of TPMS work in my car without having to re-program every time I switch tires.
Old Nov 17, 2009 | 09:37 AM
GEE35FX's Avatar
Yes you can.
BUT they have to be programmed as you thought !!
You must go to the Dealers each spring and Fall to get them reprogrammed to your car at a cost ranging from $45 to $60 each time.
That is why many including myself only run sensors for one set and have the small dash light on for the other set.
Old Nov 17, 2009 | 10:07 AM
blklude98's Avatar
Originally Posted by gian13
checked the FAQ's and this questions was left unanswered.
Originally Posted by GEE35FX
Yes you can.
I had an idea, since I also have 2 sets of TPMS, I was wondering if we could get all 8 sensors programmed at the same time so they would all be programmed to the car? I asked the infiniti tech but they never had anyone ask them that question.
Anyone that is a tech able to try?
Old Nov 17, 2009 | 10:15 AM
gian13's Avatar
Yes you can.
So having the TPMS light on for 3-5 months won't mess up the car in any way?
Old Nov 17, 2009 | 10:18 AM
canucklehead's Avatar
^ no. except the light bulb might burn out sooner!
Old Nov 17, 2009 | 12:22 PM
snotf's Avatar
sounds like a great reason to do a LED cluster conversion
Old Nov 17, 2009 | 12:23 PM
Mustang5L5's Avatar
Doesn't work that way. The system can only register 4 sensors at a time. The full size spare isn't even registered as part of the system even though it has a TPMS sensor in it.
If you wish to run 2 sets, you need to reprogram each time...or you can just live with the light on with 1 set and not worry about it. No harm having the light on all the time.
Old Nov 17, 2009 | 01:02 PM
gian13's Avatar
good info. thanks
Old Nov 17, 2009 | 01:47 PM
ttrank's Avatar
Grocery getter
Light is already an LED.
Old Nov 17, 2009 | 03:58 PM
Bassman's Avatar
I have two sets too. The first time for the new set the dealer must reprogram. I bought a tool for $25 to reprogram back and forth now. The dealer didn't charge me for the reprogram.
Old Nov 17, 2009 | 04:26 PM
GEE35FX's Avatar
Have you used the tool and successfully reprogrammed it yourself?
Old Nov 17, 2009 | 04:30 PM
GEE35FX's Avatar
It does not hurt it at all.
When you put your wheels back on with the sensors, it will start to work again fine.
I have done this with my last 3 Infinitis, but, when you don't run your sensors, you should monitor your tire pressures once in a while.
Old Nov 18, 2009 | 08:13 AM
Mustang5L5's Avatar
Do you have the Nissan tool that looks like a pistol grip controller?
If so have you used it yet? I bought it too but have not tried it yet.
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
TheKnite
Aug 14, 2015 07:59 PM
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
