Need tires size for 18x8 wheels all around on G35X
Old Nov 16, 2009 | 07:07 PM
gian13's Avatar
Before you guys try to flame me, I checked on the sticky and can't find the tires size for 18x8 wheels with a +48 offset
Should I go with 245/45/18? This is the stock size for the sedan that come with the 18 wheels, as per tirerack info. I guess this is the biggest size that will fit those wheels, right?
I'm not dropped by the way
How about 235/50/18? or 225/50/18? Would these be to big and rub?
I'm trying to keef the ride as comfortable as with the 17's
Old Nov 16, 2009 | 08:25 PM
Mustang5L5's Avatar
I'd do 255/40/18, but that's just me. Of course, this all depend on your offset, and how far you are lowered.
Typically, most recommend a tire size 2" wider than the rim, so with an 8" rim, you'd want to stick around 10" of tire width..or around 254mm. Of course, not everyone follows this, as you have guys who stretch narrower tires onto wider wheels, and other guys who put HUGE tires on narrow wheels.
Basically, play around with this
http://www.miata.net/garage/tirecalc.html
Old Nov 16, 2009 | 08:44 PM
gian13's Avatar
^^ thanks for the info man
Old Nov 16, 2009 | 10:39 PM
FlyingLumpia's Avatar
225/45/18 is roughly the same diameter as the stock 215/55/17 or if you can find a good deal on 235/45/18 that is the same diameter as stock.
Old Nov 17, 2009 | 05:24 PM
gian13's Avatar
^^ so why then the sport sedans come with stock 245/45/18 all around? just curious
Old Nov 18, 2009 | 01:17 AM
humm what I remember they came with 235/45/18. That is what my buddy had on his stocks.
Old Nov 18, 2009 | 01:25 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
05-06 sport sedans came with 235/45/18's. If you are going to lower the car, go with a 255/40. If not, then go with the 245/45.
-GP-
Old Nov 18, 2009 | 08:32 AM
gian13's Avatar
when i go to tirerack and typed 06 G35x they give me 2 options:
215-55-17's or 245/45/18
That's where I got the stock tire size from
vitamin.v
Nov 7, 2019 06:10 PM
Big C
19 Inch
11
Oct 3, 2015 05:11 AM
reaper76
Aug 5, 2015 10:13 AM
Popes
Jul 29, 2015 05:07 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
