Rota rims
Old Dec 10, 2009 | 09:12 PM
THEIFNDNIGHT's Avatar
Rota rims
I would like to know if a set rota rim 18" x 8" + 35mm offset all around is a good choice for a 2004 g35 coupe 6mt sport?
Old Dec 10, 2009 | 09:14 PM
Calvin's Avatar
Overglorified Altima
Hella tucked.
Old Dec 10, 2009 | 09:16 PM
Dubi2087's Avatar
NOPE
You would be better off with your stocker.
The offset is more for a sedan. The rears would be tucked a lot. I would get a wider wheel if you want to run the same size all the way around also a lower offset.
Old Dec 10, 2009 | 09:23 PM
OK
Cool thanks for the info Dubi2087
But what if it was a sweet *** deal?
Old Dec 10, 2009 | 09:31 PM
Dubi2087's Avatar
Depending on the deal. If you are talking about a few hundred bucks than go for it and buy some spacers for the front and rear.
Old Dec 10, 2009 | 09:43 PM
its a $800.00 set for about $425.00 brand new
what size spacer would do the job and make them fit right?
Old Dec 10, 2009 | 09:45 PM
Dubi2087's Avatar
It all the depends on the the size of the tires.
Old Dec 10, 2009 | 09:54 PM
didn't buy tires yet a little undecided about size and brand.
but i believe that since there 18" x 8" i dont have many options i have to stay in 225 Front 245 Rear range.
i
What do u recommend?
by the way i really appreciate the help.
i aslo own a 2008 jeep srt-8 and i changed the tires on that also to Yokohama 245 295
and it worked out fine but the g is a different car.
Old Dec 10, 2009 | 10:01 PM
Dubi2087's Avatar
You can do 245 all the way around or you can keep it staggered. I would just keep it staggered, since that is the way it comes stock. I would buy them, put the tires on and see how much room you have to play with before buying spacers.
On my G I have 255 and 295 on mine.
Old Dec 11, 2009 | 05:13 PM
dubi2087
So what do u think about this deal?
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_500wt_1182
i think it was a steel my stock 18" have curb rash and would cost me more to refinish.
what size tires should i run?
Old Dec 11, 2009 | 05:14 PM
i under stand why spacers i needed now it make sense u will get a straighter wheel in the back for traction looks and handling.
dseet
Oct 11, 2015 12:40 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
inexorable
17 Inch
Sep 24, 2015 10:43 AM
