Its Christmas... I need some good fitment.
Old Jan 4, 2010 | 11:11 PM
  #31
Heist.'s Avatar
Originally Posted by FlyingLumpia
If you are not rolled flat and have a good enough drop with some camber you will rub.
I think I'm going with 235/40 in the front and 255/40 in the rear. My fenders have a light roll
Old Jan 4, 2010 | 11:14 PM
  #32
gtrefever's Avatar
please do not run 40 series on 19s man your gonna get the same effect. COILOVERS is your answer
Old Jan 19, 2010 | 09:43 PM
  #33
Heist.'s Avatar
19x9/19x10
offset 35 / 40
If I had this with 225/35/19 series tires I'm going to be sitting at 25.2"
Currently on my setup its about 25.4"
So technically to get a flush setup I would have to drop an inch all the way making it 4" front and 3.5" in the back?
Can anyone tell me if this looks right? I think im getting the hang of it.
Old Jan 20, 2010 | 01:29 PM
  #34
gtrefever's Avatar
making what 4''
Old Jan 20, 2010 | 01:37 PM
  #35
Gdup35sedan's Avatar
ENVautoDetailing.com
Your bumper and sides are soo low to the ground because of the tire size. 235/40 is just too short for the sedan. Stock is 235/45/18. A 225/35/19 will do you no good as it is a tad SHORTER than the 235/40 you currently have. If you want the aggressive look, you HAVE to go lower or get 20's.
I'm on 20x8.5 +5 with a 225/35 up front, wheel poking and all, but i still have good ground clearance even with a 3 inch drop.
If i were you, i'd go 225/40F 245/40R if you plan on getting the 19x9/10 setup.
Old Jan 20, 2010 | 02:36 PM
  #36
Heist.'s Avatar
I was planning on dropping the car another inch from the current height and using 35
Old Jan 20, 2010 | 02:37 PM
  #37
that would work out very nicely.
Jusseth
Sep 13, 2020 12:25 PM
hdmark
Apr 29, 2019 04:31 PM
jcardodeucedos
Aug 27, 2015 06:28 PM
bjo16
Aug 4, 2015 09:52 AM
Soumilg
Jul 18, 2015 12:33 PM
