Rim Specs?...
Old Jan 6, 2010 | 12:54 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
Is your car lowered? If not, do you plan on lowering it? If it is, how low is it? How much camber are you willing to run? Are you willing to roll your rear fenders? Do you want beefy/normal/stretched tires?
Old Jan 6, 2010 | 12:57 PM
Drowe303's Avatar
Basically hes saying you have a lot of searching to do before you set out to buy new rims. There are a lot of things that should factor in to your choice. Learn more about different set ups and you will be a lot happier with your choice in the end.
Old Jan 6, 2010 | 01:00 PM
yes, but i'm also wanting him to answer the questions so i can give him the specs he needs to have a nice, flush setup
-GP-
Old Jan 6, 2010 | 01:42 PM
Jiggy813's Avatar
okay im getting a 07 g35 coupe soon and im probably going to be putting on the rims after i put on tint and everything will be stock and im thinking about going for 19" b/c 20" is too big for my taste and i don't understand what you mean by rolling my fenders can you show of pic of it. im basically clueless on the whole specs for rims and stuff which is my reason for asking here.
Old Jan 6, 2010 | 01:53 PM
Jiggy813's Avatar
i also do plan on lowering with a basic lowering kit either by tein or whatever good deals are out there
Old Jan 6, 2010 | 01:56 PM
Drowe303's Avatar
You need to do some searching with the search bar up there^^
Type in "fender rolling"
And "offsets"
Old Jan 6, 2010 | 02:04 PM
Jiggy813's Avatar
ya i just did that i understand the rolling but i don't think i want to do that the offset im still unclear about. if its positive does it stick out more or is it more in if its positive?
Old Jan 6, 2010 | 02:06 PM
Jiggy813's Avatar
but my only thing is i do'nt think i want to stagger only because i can't rotate. is staggering just a look or does it help with handling? just wondering.
Old Jan 6, 2010 | 05:05 PM
NjMatteSedan's Avatar
^ it helps with handling too cuz of the wider wheels and tires on the drive wheels
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
g.spot
May 9, 2016 10:54 PM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
