HELP : offsets needed for 9.5 10.5 rims
Old Jan 5, 2010 | 06:08 PM
sroks5's Avatar
I am looking to order some new 20x9.5 20x10.5 wheels but I don't know what offsets to get. I have rolled fenders and eibach prokits. I want the wheels flush with the fender. The rims will be stretched on 235/35 and 255/35 tires. Can anyone give me an idea on the offsets to get?
thank you.
Old Jan 5, 2010 | 06:24 PM
4drmadness's Avatar
hmmmm i would prolly put offsets close to 25-30 all around
Old Jan 5, 2010 | 07:41 PM
OCG35's Avatar
^^^ thats about an inch past fender line = quit a bit of neg offset...
OP when you say "flush" - you should clarify... my idea of flush is exactly what it says = right to edge of fender... others idea of flush is a type of look that usually includes lots of neg camber and stretched tires...
so I guess it depends on what you are after...
Edit - I re-read and he's stretching tire a bit... if the tire width clears you an inch or so from fender line then offsets Vivek posted might work... but the rim itself will be sticking out - then again, that might be what you are after
Old Jan 5, 2010 | 07:52 PM
4drmadness's Avatar
yea itll look weird on springs. should go more conservative i guess. prolly 35 and itll be perfect without sticking out too much
Old Jan 5, 2010 | 07:54 PM
gtrefever's Avatar
remember you cant go to high upfront with the offsets with a 9.5 cause it can hit the suspension.
Old Jan 5, 2010 | 07:55 PM
sroks5's Avatar
my definition of flush is to the edge of the fender. i am not looking for my wheels to stick out past the fender edge.
Old Jan 5, 2010 | 08:00 PM
G SEDAN's Avatar
9.5/10.5 is with stretch is not for the conservative.
I'd suggest you go with a 9/10 245/35 front and 275/30 rear. +35 front and +38 rear.
That will be just flush.
OCG35's Avatar
then 9.5 would need to be +45-48 and 10.5 would be +60 or so...
That's why you see so many guys running so much negative camber on sedans... typically you cant go that wide without running real high offsets.
Old Jan 5, 2010 | 08:03 PM
OCG35's Avatar
8.5 +35 is almost perfectly flush (very slightly tucked in)... so 9 +35 is gonna be close, but 10 +38 will be farther than flush (at least on my car - pre-flare)... he's looking at 9.5 and 10.5 though.
Old Jan 5, 2010 | 08:09 PM
sroks5's Avatar
thank you all for your help. everything makes perfect sense. looks like i will have to run some neg camber and live with the wheels sticking out a bit.
Old Jan 5, 2010 | 08:33 PM
4drmadness's Avatar
so wat offsets you going with?
Old Jan 5, 2010 | 09:04 PM
gtrefever's Avatar
likes i said you cant run to high off an offset upfront with a 9.5 you will hit your suspension!
Old Jan 5, 2010 | 09:24 PM
sroks5's Avatar
i think i am going to get some fender work done so i can run some aggressive offsets like +6 upfront and +12 in the rear. how much of a flare would i need?
Old Jan 5, 2010 | 09:26 PM
4drmadness's Avatar
oh damn nice!!! hmmm get coilovers first tho. and a rear camber kit as well. You wud def have to pull the rear a decent amount to make it not hit the fender, also around -4 camber rear, or more. i mite go a little more aggressive as well, but i need a pull first.
Old Jan 5, 2010 | 09:39 PM
gtrefever's Avatar
9.5+6 run a 225/35 your gonna need a really small pull upfront
10.5+12 235/35 and a slight pull will be needed.
and im hoping that youll dumpt your car.
