Can i put acura tl type s wheels on my g35? What would i have to do!
Old Jan 11, 2010 | 12:51 PM
getyourgwapupp's Avatar
I got a set of the tl type s wheels in gunmetal and i wanna put them on my 03 g35 coupe, would i need spacers if so wat type fron or rear or all?
Old Jan 11, 2010 | 12:58 PM
Old Jan 11, 2010 | 01:26 PM
04G35NYC's Avatar
Why would you want to put OEM Acura wheels on a Infiniti i am confused...
Old Jan 11, 2010 | 01:51 PM
Originally Posted by 04g35nyc
why would you want to put oem acura wheels on a infiniti i am confused...
they look good, i got the car lowerd so im just inlove with the looks of those stock 19 from acura!
But the question is would they fit with no problem?
Old Jan 11, 2010 | 01:56 PM
Jeff92se's Avatar
Red Card Crew
Probably would fit but why? They are only 17"
Old Jan 11, 2010 | 02:20 PM
eurodre's Avatar
i believe thread pattern is different but ill get back to you on this one
17x8 +45 all around (oem tl dunno for sure for sure about type s)
Old Jan 11, 2010 | 02:29 PM
WhosRich's Avatar
As far as bolt patterns, theyre the same as infiniti. I dunno about the offsets though.
Old Jan 11, 2010 | 02:34 PM
joedaddy1's Avatar
i think honda/acura's typically have a smaller bore size than nissan/infiniti..
actually nissan/infiniti usually have the biggest bore sizes..
i know for sure nissan wheels fit toyotassssss
Old Jan 11, 2010 | 02:38 PM
Jeff92se's Avatar
Red Card Crew
No fit. Nissan 66.1, Acura 64.1 hub bores.
Old Jan 11, 2010 | 02:45 PM
Wow thank you guys for the wonderful feedback!
Old Jan 11, 2010 | 02:47 PM
eurodre's Avatar
hub rings.
Old Jan 11, 2010 | 02:49 PM
Jeff92se's Avatar
Red Card Crew
Ah there is no hub ring fix for this. You can't make the Nissan hub bore smaller no matter what ring you use.
Old Jan 11, 2010 | 02:53 PM
eurodre's Avatar
hmmm this might be true
Old Jan 11, 2010 | 02:57 PM
Jeff92se's Avatar
Red Card Crew
LOL. Think about it man.
Old Jan 11, 2010 | 03:05 PM
eurodre's Avatar
lol well then someone needs to take that up and make hub rings from big to small hub bores
edit: nvm data is wrong
