going aggressive - need advice on 20x13.5
Old Jan 11, 2010 | 03:45 PM
a7med's Avatar
I made up my mind on Work VS-xx rims for my G coupe 04 (currently on stock 17s, non-brembo, dropped 1.5", with camber and toe kit). I certainly want 20's, I was wondering what offset I need to make 13.5 fit for rear while keeping fender work to the minimum? I believe I need the lowest offset I can go for, whats the lowest offset I can go for?
Old Jan 11, 2010 | 03:48 PM
Kris79's Avatar
battle froggy
are you for real 20x13.5?
Old Jan 11, 2010 | 04:01 PM
ShanesG's Avatar
Lol, good luck!!!
Old Jan 11, 2010 | 04:02 PM
jalilig35's Avatar
lol
Old Jan 11, 2010 | 04:07 PM
GR6RR's Avatar
hot dang!
Old Jan 11, 2010 | 04:14 PM
a7med's Avatar
seriously guys, I already got quote for it and ready to buy.
no one's done it? someone must've done it! i only need advice on rear rims, fronts i am thinking 9.5
Old Jan 11, 2010 | 04:21 PM
CandlestickPark's Avatar
ill Sedan
20 x 13.5, can't wait to see this....
Old Jan 11, 2010 | 04:37 PM
Frankieg35's Avatar
Haha yeah i need to see this..
Old Jan 11, 2010 | 04:47 PM
ShanesG's Avatar
9.5/13.5 lol oh boy.
Well for starters there is no way it's gonna work w.o some significant fender work cause you will need a low offset if you are even thinking about it having any inner clearance. So pretty much it's not gonna happen.
Put it this way. I just went out to measure this for you. And with my pulled and flared fenders it's exactly 13.5" from the shock tower to the fender. For reference i'm running a 20x12 with a -8 offset. You will have to run something equivalent, ie. 20x13.5 +10 and even then i wouldn't do it(i would go more aggressive). Your wheels camber in as you compress so one hard dip and your wheels is now getting effed up while effing up your shock tower. IMHO i wouldn't go more than 12.5, and especially with 20's. You are going to have to do extensive fender work, a good amount of camber and ALOT of stretch for this to work.
Old Jan 11, 2010 | 04:51 PM
Kris79's Avatar
battle froggy
i didnt even know work made wheels larger than 12.5
Old Jan 11, 2010 | 05:21 PM
Q8y_drifter's Avatar
i love the aggressive look but...
HenryLee's Avatar
Wow! 9.5 fronts and 13.5 rear? Why!? Just go w/ 10.5 fronts and 12.5 rears.
Old Jan 11, 2010 | 05:23 PM
HenryLee's Avatar
^^^ actually take that back. I want to see how this looks. Just do it. It hasnt been done before, but dont let people tell you it cant be done. But consider getting 10.5 front wheels.
Old Jan 11, 2010 | 05:33 PM
str8dum1's Avatar
An 11" +24 just clears the inner suspension.
ShaneG, you have almost 2cm more inner clearance than me.
for the same inner clearance on a 13.5 as the 11"+24you'd need a 13.5 -8.
and then that would extend past the fender like a 10.5" -46 ! That would barely fit a widebody
Old Jan 11, 2010 | 05:38 PM
a7med's Avatar
glex is/has been doing/trying to do it for a while now, been following his threads:
https://g35driver.com/forums/media-s...on-2009-a.html
