what size spacers with stock 19's?
Old Jan 15, 2010 | 09:09 AM
bina12834's Avatar
title says it all. im looking to get spacers, but dont know a thing about them. what size should i get with stock 19's and stock ride height?
Old Jan 15, 2010 | 10:41 AM
HenryLee's Avatar
25mm all around is pretty flush. I would do 25mm front and 30mm rear to be little aggressive. Use the search, theres a member that ran this setup on this stocks came out perfect.
Old Jan 15, 2010 | 10:54 AM
bina12834's Avatar
i tried to run a search for spacers, but too much garbage came up for me to sort through.
Im looking more for a flush look than aggressive, but ill have to check out some pics.
Is there a brand of spacers that better than another?
Old Jan 16, 2010 | 06:35 PM
Xet's Avatar
Xet
brand doesn't really matter. i have 25 all around, I might switch to 25/30 in the future, it looks amazing 25/30 i just didn't get it in the beginning because a few people warned me that it maybe unsafe. i have no idea about the validity of this claim though.
Old Jan 16, 2010 | 08:09 PM
DrewTheSuit's Avatar
25 f, 30 r
Old Jan 16, 2010 | 08:30 PM
seymore4's Avatar
m56
I have 20mm all around and like it. Not "hella flush" but not tucked anymore, good middle ground IMO.
I'd say look up some pictures of how flush you want to be and get something between 20-30mm.
Old Jan 17, 2010 | 11:12 PM
BlacknTan's Avatar
before I was lowered I ran 20's all around and they looked pretty good, but once I was dropped I needed to run a bigger spacer. I'm runnin 25's in the front and 30's in the rear and it looks great. I rolled my rears just in case,,,really wasn't hard
Old Jan 17, 2010 | 11:38 PM
Gargan's Avatar
Check out this thread: https://g35driver.com/forums/media-s...s-oem-19s.html
Old Jan 18, 2010 | 05:25 PM
Gargan's Avatar
And I just found out at stock height, 25mm on the rear with 275 tires will rub.
Old Jan 18, 2010 | 06:19 PM
bina12834's Avatar
im thinking of going 20f 25r. i saw your pics in that thread you posted Gargan....are you on stock ride height?
Old Jan 18, 2010 | 06:23 PM
bina12834's Avatar
oh im on stock tire size too btw
Old Jan 18, 2010 | 06:25 PM
Gargan's Avatar
Yeah stock height. And 20/25 spacers.
They were problem free until I had 275s put on this afternoon.
Old Jan 18, 2010 | 06:42 PM
caketech's Avatar
i would recommend you get 25mm all around. maybe even 25/30
if you do end up getting 25 or 30 in the rear you should probably roll the fenders.
depending on some spacers
on a local forum i go to, someone got 20mm, and the stock studs stuck out so he had to grind them off to get the wheels on.
just something to consider.
Old Jan 18, 2010 | 09:51 PM
Gargan's Avatar
Was that on a G? I didn't have that problem with my 20mm.
Old Jan 18, 2010 | 10:10 PM
aBLUEg35's Avatar
i had 20f and 25r on stock 19s with the stock sport suspension it looked great but you could def go 25f 30r and it would look nice and flush! ps i dont think youd have to roll anything
marsman328
Northern California
Aug 11, 2015 07:29 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
