Help- Springs, H Tech or S Tech, G or Z????
Old Aug 31, 2004 | 09:59 AM
Brando's Avatar
I want to get rid of the SUV gap over my tires....but,
car s a daily driver so I don't want it too low or stiff.
Anyone with experience please give me some input.
I don't want it so low I have rubbing or camber problems.
I have heard some people used the H Tech for the Z?
I'm running 18"'s - 9"f w/ 245/40 & 10" r w/ 275/40
Thanks!
"I like you.....You remind me of myself when I was young and foolish"
Old Aug 31, 2004 | 06:28 PM
glennp_1999's Avatar
Re: Help- Springs, H Tech or S Tech, G or Z????
s-techs should be fine for you since you're riding on 18's. the h-techs won't lower your car that much if you want to get rid of that suv gap you're talking about.
<font color=blue>04 CB COUPE / WILLOW / PREM PACK</font color=blue>
Old Aug 31, 2004 | 07:46 PM
av8r's Avatar
s techs 1.2-inch Drop Front And 0.9-inch Drop Rear
h techs 0.6-inch Drop Front And 0.3-inch Drop Rear
Here is some info on spring rates from Gsedan35
Oem springs
Front:314 Rear:342
Tein S-tech G35 coupe & sedan (fronts are progressive, rears are linear)
358/274 R+14% R-18%
Transfers +32% roll stiffness to front
Tein H-tech G35 coupe & sedan(fronts are progressive, rears are linear)
324/260 F+ 5% R-22%
Transfers +27% roll stiffness to front
Eibach's as noted (first number is the softer initial rate, followed by the higher final rate)
350Z 296/384 front 316/421 rear
G35c 229/337 front 274/463 rear
G35s 259/334 front 359/413 rear
RSR 350Z springs (just a wee bit progressive F&R, maybe one coil is progressive)
345/417 F+10% R+22%
Transfers +12% roll stiffness to rear
RSR G35 coupe springs (progressive front and rear)
315/315 F+0 R-8%
Transfers +8% roll stiffness to front
Hotchkis 350Z springs (linear springs)
340/330 F+8% R-3%
Transfers +12% roll stiffness to front
Tein S-tech 350z (fronts are progressive, rears are linear)
386/402 F+23% R+16%
Transfers +7% roll stiffness to front
Tein H-tech 350z (fronts are progressive, rears are linear)
358/375 F+14% R+11%
Transfers +3% roll stiffness to front
Tanabe GF210 Series 350Z (progressive)
336/375 F+7% R+10%
Transfers +3% roll stiffness to rear
Tanabe NF210 Series 350Z (progressive)
314/353 F+0 R+3%
Tanabe NF210 Springs G35 COUPE (progressive)
297/336 F-5% R-2%
Tanabe DF210 Springs G35 COUPE (progressive)
308/353 F-2% R+3%
Transfers +5% roll stiffness to front
Tanabe NF210 Springs G35 SEDAN (progressive)
297/269 F-5% R-21%
Transfers 17% roll stiffness to front
Tanabe DF210 Springs G35 SEDAN (progressive)
286/280 F-9% R-18%
Transfers +9 roll stiffness to rear
04' Sedan 6MT Silver/Graphite/Premium/Aero/HuperOptik/XM
Z-Tube / Stillen- Sways, Airbox & Grounding Kit
19x8.5/9.5 Hiros / S-03s 245/40 & 275/35zr19
Coupe Suspension
Old Sep 1, 2004 | 08:19 AM
Brando's Avatar
Thanks!
Wouldn't you want to transfer more roll stiffness to the rear of the G coupe?????
Old Sep 1, 2004 | 06:09 PM
av8r's Avatar
Yeah, transfering roll to the front will increase understeer. A few percent change won't be noticeable though. I am about to put the 350z H Techs on my sedan (should lower 1.3f and 1.2 rear with only 3% roll stiffness added to the front). I am not sure how much these would lower your car. I think .2 in the rear and probably 3/4 inch in the front on yours. Contrary to popular belief the front springs are not the same on the z and the G coupe. The rears are the same length though, so I am pretty confident about the .2 in the rear. There is another coupe running 350z H techs in this forum. I suggest you run a search or post a question like, "Anyone running 350z H techs on their coupe?".
Off subject, what do you fly?
Coupe Suspension
KruZZe
Feb 27, 2023 05:04 PM
DRG35R
Jan 31, 2016 07:14 AM
prinny
Nov 22, 2015 11:07 PM
AJC128
Nov 1, 2015 11:55 AM
