need new rubber ...
Old Feb 6, 2010 | 02:27 PM
WILLIE BEANS's Avatar
Question need new rubber ...
ok so i have a 2003.5 sedan ..
ive still got these stock wheels
17" 6 spoke (Sedan std)
Front & Rear: 17"x7" (+45mm)
so now its time to get new tires all around ...
and most likely will go with stock tires (215/55-17) all around ..
but heres my question ..
im thinking i might want wider tires in the rear ..
(why you ask ??? just to have a fatter rear tire .lol)
here im comparing stock 215/55-17 with 235/50-17
you guys have any idea if this would work??
could i go bigger in the rear ??
..or
dont even bother doing it ...????
any and all opinions and comments please ...
thnx ...
Old Feb 6, 2010 | 02:50 PM
Bassman's Avatar
Do it if you want. It will work fine. I threw on a set of 235/50-17's all the way around last summer.
Old Feb 6, 2010 | 03:26 PM
azt108's Avatar
I have 225/50/17 on those wheels. In fact, I never realized that it wasn't the stock specs until I read the sticker alongside the door. Anyway, the differences listed are incredibly minute to the point that their are virtually no differences. Additionally, the 225s have no issue during the alignment process or when driving around. The .23% difference in mph reading is negligible. Here are some advantages I can think of between the 235 vs. 215 tires:
215s:
1. Meets OEM specs
2. Theoretically better traction in snow
3. Higher wheel height means less of a gap between the body and tire
235s:
1. Better dry road traction
2. Since they are wider, they provide a cushion of protection against curb rash since the tire will stick out further from the wheel than 215s.
3. Look better IMO
OP Let us know what you decide. Hope this helps.
Forum: Please add/ counter with explanation, anything on this list that would be helpful.
Old Feb 6, 2010 | 03:37 PM
gian13's Avatar
How about buying 225/55/17??? I'm ready to buy 4 of these. Basically the same hegith just a little wider.
Anyone has these tires on on a G35X?
Old Feb 6, 2010 | 03:44 PM
ok so after these few posts ..
it looks like im going to go 235/50-17's all around now ..
unless..
i go wider for the rear ? if so .. what size ??
guess im thinking/trying to make up for the lack of aftermarket wheel/tire funds . lol ..
Old Feb 6, 2010 | 04:01 PM
azt108's Avatar
Good choice cause aftermarket wheels f up your stock suspension. Plus most of them are heavier than the stock and kill your performance (fine line between aesthetics and performance). Go 235 all round so you can properly rotate your tires. Plus it makes sense economically.
Old Feb 6, 2010 | 05:13 PM
4DGS's Avatar
Just buy new wheels, you can pick up used wheels with tires for like $1400, you're going to be spending like $600 in tires anyways.
Old Feb 6, 2010 | 07:42 PM
Mustang5L5's Avatar
Not sure i'd go any wider than a 235 on a 7" wide wheel. Typically the rule is a tire 2" wider than the rim size is the max you should really go. A 235 is 9.25" wide..which is fine.
But rules are meant to be broken, Tons of guy do the stretched tire look (not a fan personally) and other guys go for the bulge look.
I actually run 275's on a 8" wide wheel. That's almost 11" of rubber, so 3" bigger than the rim. (It's not on my G35 though)
Since i'm not getting 18's or 19's anymore, i think i'm gonna go with the 235/50/17's myself. I know the wider rubber isn't ideal for snow...but it's only 20mm. Shouldn't be a huge difference.
Old Feb 7, 2010 | 08:24 AM
VQEric's Avatar
Anybody have any pics of 235/50/17's on stock wheels?
Old Feb 7, 2010 | 04:07 PM
Bestswat's Avatar
you'll be fine with 235, there is really no downfall in your case. You should save and buy yourself a set of rims for the summer though. It's still winter you have time.
Old Feb 7, 2010 | 07:13 PM
NFSP G35's Avatar
? = 2B || !2B
^+1
If you play your cards right, you can get them for less than that
Old Feb 7, 2010 | 07:22 PM
Mustang5L5's Avatar
Found a pair of M45 19" for sale on CL for $1000 the other day. I'd buy them except that I just spent $1500 on wheels and new rubber for my Mustang.
New wheels for the G will have to wait til next Xmas.
Old Feb 7, 2010 | 07:28 PM
NFSP G35's Avatar
? = 2B || !2B
^OP is in NY, where are the wheels?
Old Feb 7, 2010 | 07:35 PM
Mustang5L5's Avatar
MASS. I'll see if i can find it again, but it was actually a week ago. Unsure if it will still be listed
Old Feb 8, 2010 | 10:38 AM
thnx for the suggestions guys .. (thumbsup)
Originally Posted by nfsp1
^+1
i know the wheels i want and dont want to skimp on a set
im not fully in love with .. lol ..
but not looking to get wheels right now ..
im moving to florida .. soon as things pick up ..
replacing my tires is more of a necessity .. current ones are shot ..
thnx for the help gents ..
