One wheels burnout
Old Feb 10, 2010 | 10:16 PM
Ginevan's Avatar
affect is passion, such as affection.
Effect is what happens after the cause.
Old Feb 10, 2010 | 10:20 PM
AARONHL's Avatar
Originally Posted by Gnightsedan
When u turn VDC off the LSD is not in effect, correct?
Incorrect, the VDC is a completely different system than the LSD. Vehicle Dynamics Control will use brake or throttle to control the vehicle if it starts to slide on ice, rain, etc. A Limited Slip Differential will be used to gain better traction in all conditions; giving either wheel the correct amount of power.
Old Feb 10, 2010 | 10:51 PM
Mustang5L5's Avatar
VDC is an electrical safety system. A LSD is a mechanical component in your rear differential which allows power transfer between both rear wheels.
Old Feb 11, 2010 | 12:08 AM
Hammerhead i-Eagle Thrust's Avatar
Originally Posted by Wannabe6MT
................. your car will always do that. If both wheels always lit up, you'd drag a wheel every time you took a turn. One wheel peels are expected unless you have a limited slip dif, which you do not, because your car is an 04 and they didnt get a limited slip.
6 speed 04s have LSD
and what is a 225/46-19?
Old Feb 11, 2010 | 12:14 AM
Neu Era's Avatar
damn i wish i had LSD!!!
Old Feb 11, 2010 | 02:29 AM
nazc0's Avatar
2006 Vortech supercharged Sedan
damn lol miss typed that 225 35 19 im not quite sure how i cocked that up
Old Feb 11, 2010 | 10:56 AM
lol
Old Feb 11, 2010 | 11:14 AM
LightsOut's Avatar
SIETESG
so did autos, but they had to have sport package
if someone doesnt have lsd it can always be purchased.
Old Feb 11, 2010 | 11:19 AM
nazc0's Avatar
i dont care about it that much as to go out and replace a perfectly working diff
later on down the road that may be a possibility
Old Feb 11, 2010 | 11:33 AM
LightsOut's Avatar
SIETESG
your just adding mechanical parts to your diff.
Old Feb 11, 2010 | 11:40 AM
nazc0's Avatar
wait, you just add some things to the diff? i thought you just replace it
how much would it cost to get it to be a lsd
Old Feb 11, 2010 | 11:49 AM
LightsOut's Avatar
SIETESG
actually much easier to get the whole pumpkin...
cheap really.
sorry for the mix up.. your right its the whole diff, but its worth it, if you want lsd
ebay add
http://cgi.ebay.com/ebaymotors/Diffe...Q5fAccessories
there is also this option.
nismo lsd
https://g35driver.com/forums/3801891-post1.html
Old Feb 11, 2010 | 12:18 PM
its not listed on edmunds
2004 Infiniti G35 Available Features
Style:
4dr Sedan w/Leather, Automatic
Standard Features
3.5L V6 DOHC 24V FI Engine Regular Unleaded Fuel Required
5-Speed Shiftable Automatic Transmission Variable Valve Timing
Rear Wheel Drive Multi-Link Front Suspension
Four-Wheel Independent Suspension Multi-Link Rear Suspension
Front and Rear Stabilizer Bars Clock
Compass External Temperature Display
Low Fuel Level Indicator Tachometer
17 Inch Alloy Wheels All Season Tires
P Tires Tire Pressure Monitoring System
V-Speed Rated Tires Interior Mounted Spare Tire
Temporary Spare Tire Stability Control
Traction Control Braking Assist
Electronic Brakeforce Distribution Front Ventilated Disc Brakes
Rear Ventilated Disc Brakes 4-Wheel ABS
Driver and Passenger Front Airbags Front and Rear Head Airbags
Front Side Airbags Child Safety Locks
Child Seat Anchors Emergency Trunk Release
Rear Center 3-Point Belt Seatbelt Force Limiters
Seatbelt Pretensioners Anti-Theft Alarm System
Engine Immobilizer 5 Passenger Seating
Front Bucket Seats Leather Seating
Manual Driver's Seat Lumbar Adjustment Front Seat Whiplash Protection System
Heated Passenger Seat Heated Driver's Seat
Power Driver's Seat Power Front Passenger Seat
Front Adjustable Headrests Pass-Thru Rear Center Armrest
Rear Bench Seat Rear Ventilation Ducts
Steering Wheel Audio Controls Cargo Net
Cruise Control Steering Wheel Cruise Controls
Cupholders Door Pockets
First Aid Kit Front Center Console With Storage
Front Power Outlet Multi-Function Remote
Overhead Console With Storage Power Steering
Remote Trunk Release Retained Accessory Power
Seatback Storage Tilt Steering Wheel
Alloy and Leather Shift **** Trim Alloy Center Console Trim
Alloy Dash Trim Alloy Door Trim
Cargo Area Light Carpeted Floor Mats
Front Floor Mats Leather Steering Wheel Trim
Reading Lights Rear Floor Mats
Air Filtration Automatic Climate Control
Intermittent Windshield Wipers One-Touch Power Window(s)
Rear Defogger Remote Window Operation
Speed Sensing Windshield Wipers Remote Power Door Locks
Automatic On/Off Headlights Front Fog/Driving Lights
Xenon High Intensity Discharge Headlights Auto-Dim Rear View Mirror
Heated Exterior Mirrors Illuminated Vanity Mirror(s)
Power Exterior Mirrors AM/FM/Cassette/CD Changer Audio System
Antenna Radio Data System
Cargo Tie Downs
Available Optional Features
17 Inch Chrome Alloy Wheels AM/FM/Cassette Audio System
Bose Audio Fullsize Matching Spare Tire
Leather and Wood Shift **** Trim Multi-Zone Climate Control
Navigation System Power Glass Sunroof
Rear Spoiler Reclining Rear Seat
Satellite Radio System Trip Computer
Universal Remote Transmitter Wood Door Trim
Style:
4dr Sedan w/Leather, Manual
Standard Features
6-Speed Manual Transmission Variable Valve Timing
Limited Slip Rear Differential Rear Wheel Drive
Multi-Link Front Suspension Four-Wheel Independent Suspension
Multi-Link Rear Suspension Front and Rear Stabilizer Bars
Clock Compass
External Temperature Display Low Fuel Level Indicator
Tachometer 17 Inch Alloy Wheels
P Tires Performance Tires
Tire Pressure Monitoring System V-Speed Rated Tires
Interior Mounted Spare Tire Temporary Spare Tire
Stability Control Traction Control
Braking Assist Electronic Brakeforce Distribution
Front Ventilated Disc Brakes Rear Ventilated Disc Brakes
4-Wheel ABS Driver and Passenger Front Airbags
Front and Rear Head Airbags Front Side Airbags
Child Safety Locks Child Seat Anchors
Emergency Trunk Release Rear Center 3-Point Belt
Seatbelt Force Limiters Seatbelt Pretensioners
Anti-Theft Alarm System Engine Immobilizer
5 Passenger Seating Front Bucket Seats
Leather Seating Manual Driver's Seat Lumbar Adjustment
Front Seat Whiplash Protection System Heated Passenger Seat
Heated Driver's Seat Power Driver's Seat
Power Front Passenger Seat Front Adjustable Headrests
Pass-Thru Rear Center Armrest Rear Bench Seat
Rear Ventilation Ducts Steering Wheel Audio Controls
Cargo Net Cruise Control
Steering Wheel Cruise Controls Cupholders
Door Pockets First Aid Kit
Front Center Console With Storage Front Power Outlet
Multi-Function Remote Overhead Console With Storage
Power Steering Remote Trunk Release
Retained Accessory Power Seatback Storage
Tilt Steering Wheel Alloy and Leather Shift **** Trim
Alloy Center Console Trim Alloy Dash Trim
Alloy Door Trim Cargo Area Light
Carpeted Floor Mats Front Floor Mats
Leather Steering Wheel Trim Reading Lights
Rear Floor Mats Air Filtration
Automatic Climate Control Intermittent Windshield Wipers
One-Touch Power Window(s) Rear Defogger
Remote Window Operation Speed Sensing Windshield Wipers
Remote Power Door Locks Automatic On/Off Headlights
Front Fog/Driving Lights Xenon High Intensity Discharge Headlights
Auto-Dim Rear View Mirror Heated Exterior Mirrors
Illuminated Vanity Mirror(s) Power Exterior Mirrors
AM/FM/Cassette/CD Changer Audio System Antenna
Radio Data System Cargo Tie Downs
Multi-Zone Climate Control Navigation System
Power Glass Sunroof Rear Spoiler
Reclining Rear Seat Satellite Radio System
Trip Computer Universal Remote Transmitter
2005 Infiniti G35 Available Features
Style:
4dr Sedan w/Automatic
17 Inch Chrome Alloy Wheels 18 Inch Alloy Wheels
Auto-Dim Rear View Mirror Automatic On/Off Headlights
Hands-Free Multi-Function Remote Leather and Wood Shift **** Trim
Limited Slip Rear Differential Multi-Zone Climate Control
Satellite Radio System Universal Remote Transmitter
Wood Dash Trim Wood Door Trim
apparently its standard on the 04 6mt but not available on 04 5at and optional on the 05 5at(sport package i guess)
Old Feb 11, 2010 | 12:20 PM
GAU-8's Avatar
Looks 10X easier to do than other diff swaps I've seen. I didn't realize the axles were bolted to the diff. Maybe a cpl hrs to swap that out?
Old Feb 11, 2010 | 12:26 PM
  #30
LightsOut's Avatar
SIETESG
Style:
Style:
Style:
maybe your info is correct.
I've always been told and read on here 04 with sport package have lsd for the sedans. Cause I know the coupes had that option.
