Looking at a set that run 19x9.5/10.5 at +25 all around. Dropping on S-Techs. Will they fit?
Tires would be 245/35 and 275/30 respectively.
Go to the tech section under wheels and tires and look for a thread discussing offsets and wheel fitment. Your offsets are to aggressive.
CandlestickPark
ill Sedan
close
- Join DateJun 2007
- LocationLong Beach, SoCal
iTrader Positive Feedback100
iTrader Feedback Score(87)
Liked:2,688 Times in 1,449 Posts
Yes those will fit. Rears would need to be pulled. Fronts would have to be rolled and slightly pulled.
S-techs are not even close to being low enough to pull this look off. You are going to need a nice drop on coils and some camber for this to work.
considering he is X, and the tire size he listed. The answer is still NO.
CandlestickPark
ill Sedan
close
- Join DateJun 2007
Quote:
Didn't see that he was an X, I was on my iPhone.Originally Posted by G SEDAN
He can do 225/40 and 255/35 and that setup would work. Ernie (FlyingLumpia) is running the same tire size on his 9/10 staggered setup. Still needs to go a lot lower though.Registered User
but he didnt ask how he can make it fit! he asked if it will fit. and i gave him an answer!
I'm such an assshole
CandlestickPark
ill Sedan
close
- Join DateJun 2007
^This guy...
Quote:
we're in a sedan section Originally Posted by ShanesG
Woops my bad op thought you were a coupe -____-
It can fit with rolled fenders and enough camber. you may want to run smaller tire sizes so you wont need as much negative camber.
