G37 OEM Wheels
on
G37 OEM Wheels
Before I start - yes I searched and maybe I'm bad at using the search button, but I couldn't find anything that I hadn't seen the last time I checked, 6 months ago. So please give me a break and help me
ANYWAY, I'm looking to pick up the G37 OEMs:
Has anyone does this on stock ride height? If so, pictures?
If I lower it, I want a VERY subtle drop, just so it makes the 19s look like it's a stock ride. Would the 350Z springs do the trick? Or has anyone used anything that worked better? Regardless, also, pictures would be great.
Also, do I need to make any other modifications to fit this wheel properly? Do I need spacers? C&C Kit?
And very lastly, does ANYONE have pictures of these wheels on a TB sedan? I've yet to see it..
Thanks for the responses in advance!
I got these in the mail. They're getting here this week and i'm going to throw them on a sedan at stock height and take some photos. I'll post them up. You need g37 infiniti lug nuts. These wheels require thier own specially designed lug nuts. They're like $260 at the stealership so you need to try to find a seller that has them with the wheels. I have the same exact concerns as you. How would these look with a Z suspension or Z/G suspension. Should i go with coilovers and slam it? For now I'm leaning towards coilovers but some prior examples would have been great.
Stock '04 lugs won't fit OEM G37 wheels. You'll be able to tell as soon as you pair them up. I got my newer-style lugs at the link below. They were just under $2 a piece, so better than $260 at the stealership.
http://www.calwheelaccessories.com/f...e-mag-lug-nuts
on
